Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 50
  1. #11
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,622
    I have some questions regarding your drawing from an architectural point of view.
    Ground floor
    -Why are the proposed external walls thicker than the existing external walls?
    -Are you actually going to remove/replace the back wall of the garage?
    -What are the two objects labeled "RL Over"? Are they skylights?
    -The utility room is quite large. What exactly will be located in this room?
    First floor
    -Why just one very large window in the bedroom?
    -You should probably show where the toilet, shower/bathtub, sink/vanity are going to be situated in the en suite.
    -Exterior wall thickeness?
    -How does one go from the ground floor to the first floor? I don't see a stairway.
    Roof plan
    -Could you explain what is going on with the roof? I'm not sure I understand.
    -What does the existing roof on the garage look like? Is it flat?
    Aren't you required to provide at least two elevations (front and side) in your submission?
  2. #12
    Full Member
    Caesium's Computer Details
    Windows 10
    Asus Sabretooth X79
    Intel i7 3820 3.6GHz
    32.0 GB
    Nvidia GeForce GTX 770
    Samsung SSD 500GB
    Hitachi Ultrastar 1TB
    Twin Dell S2740L
    AutoCAD 2016
    Jan 2016
    25
    Ground floor
    -Why are the proposed external walls thicker than the existing external walls? Building code dictates that 100mm leaf with 100mm insulation then 100mm leaf hence the thickness. Existing house built before legislation introduced.
    -Are you actually going to remove/replace the back wall of the garage? There is a steel beam over the back of the garage to support the elevation above, Exisitng wall will just be plastered when it's inside.
    -What are the two objects labeled "RL Over"? Are they skylights? Yep
    -The utility room is quite large. What exactly will be located in this room? I am thinking about sub dividing this room and having a gym in the other half
    First floor
    -Why just one very large window in the bedroom? To match existing front window in main house, the side will overlook another property and probably will not be able to have any fenestration.
    -You should probably show where the toilet, shower/bathtub, sink/vanity are going to be situated in the en suite. Yes I can do this, thought about leaving that for now as the planners don't require it and it would be added to construction drawings.
    -Exterior wall thickeness? 300mm
    -How does one go from the ground floor to the first floor? I don't see a stairway. Still need to add this
    Roof plan
    -What does the existing room on the garage look like? Is it flat? Yes
    I have a few more things to add to the drawing, it just struck me that I might ask for advice before committing any more time to finishing the drawing if I couldn't print it due to a formatting error.
    if I'd made some catastrophic mistake in the scale and had to draw it all over again I'd be miffed so thought I'd ask the question before committing any more time, that's all.
    Here's some sketchups I thought I could use as elevations
  3. #13
    Full Member
    Windows 10
    Asus Sabretooth X79
    32.0 GB
    Samsung SSD 500GB
    Twin Dell S2740L
    AutoCAD 2016
    Jan 2016
    25
    I have replied but it's awaiting admin permission to post?
  4. #14
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,622
    Not sure why that would be. Did you post banned images or use swear words? LoL
  5. #15
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    Southern California
    10,195
    No, he posted his images through an external file host instead of uploading them to the forum.
    Post #12 is now approved.
    Information for new members: http://www.cadtutor.net/forum/showth...or-new-members
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
  6. #16
    Full Member
    Windows 10
    Asus Sabretooth X79
    32.0 GB
    Samsung SSD 500GB
    Twin Dell S2740L
    AutoCAD 2016
    Jan 2016
    25
    Wasn't sure we could upload, I saw attachments and they're different beasts. Not many forums allow embedded local images.
    Every day is a school day eh.
  7. #17
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,622
    Thanks for the images and for answering my questions.
  8. #18
    Full Member
    Windows 10
    Asus Sabretooth X79
    32.0 GB
    Samsung SSD 500GB
    Twin Dell S2740L
    AutoCAD 2016
    Jan 2016
    25
    Does it make sense?
  9. #19
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,622
    For the most part it does. What type of insulation is being used in the exterior walls? I'll be curious as to what the addition of the stairway will do to the overall interior design.
  10. #20
    Full Member
    Windows 10
    Asus Sabretooth X79
    32.0 GB
    Samsung SSD 500GB
    Twin Dell S2740L
    AutoCAD 2016
    Jan 2016
    25
    100mm celotex most likely.
  1. Window scaling paper space
    By rubio_jose in forum AutoCAD General
    Last Post: 1st Nov 2015, 01:34 pm
  2. Scaling in paper space
    By raley123 in forum AutoCAD Beginners' Area
    Last Post: 7th Mar 2013, 07:01 am
  3. Paper Space Scaling
    By Buddy Love in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 27th Feb 2013, 03:24 pm
  4. Scaling Malfunction In Paper Space
    By annjeweliette in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 7th Jul 2010, 12:17 am
  5. yet another paper space scaling question
    By raekwon in forum AutoCAD Beginners' Area
    Last Post: 24th May 2006, 09:20 pm
