Slumi Posted January 27, 2016 Share Posted January 27, 2016 Hello I have some problem to solve. Firstly sorry for my poor English Some 2d drawings where delivered to me and I have to make them smaller but in the way that every edge is moved into the drawings a certain dimension. It's hard to explain in words I think that .dwg will explain better. I have attached two examples where the upper i cannot done. But the lower example is correctly. In the .dwg there is also finally product. Could you explain me how to do it properly ? In some objects i cannot set angle more then certain amount because "The Draft angle results in a self intersecting body" I will be greatful for your help Taper faces.dwg Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 27, 2016 Share Posted January 27, 2016 This question needs to be moved to the 3D forum as that is where it properly belongs. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 2, 2016 Share Posted February 2, 2016 I'm sorry to hear that. I took a look at your drawing but as soon as I realized splines were involved I stopped. I don't much care for them and hardly if ever need to use them in my day-to-day job. Quote Link to comment Share on other sites More sharing options...
Slumi Posted February 2, 2016 Author Share Posted February 2, 2016 I have found some solution, edit that object into the polyline whit high precision, then use "offset" then set distance - >object -> and direction .... ohh it was so easy ... Quote Link to comment Share on other sites More sharing options...
Dadgad Posted February 2, 2016 Share Posted February 2, 2016 I have found some solution, edit that object into the polyline whit high precision, then use "offset" then set distance - >object -> and direction .... ohh it was so easy ... Congratulations, nicely done, and thanks for sharing the solution which you used. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 2, 2016 Share Posted February 2, 2016 Good to hear you found a solution. Thank you for updating us. Quote Link to comment Share on other sites More sharing options...
