andybeedub Posted January 27, 2016 Share Posted January 27, 2016 Hi All new to the forum but not to AutCAD I'm on 2002 still with Windows 7 but havng worked in other offices its a common problem When a dwg is minimised it sits in a very small box in bottom LH corner, when multiple dwgs open and minimised it is impossible to see which dwg is which. On maximising the wrong dwg and then minimising it is so fast i cannot trace where in the stack each dwg sits. I'd like the dwg title to appear when the cursor hovers each minimised title - is this possible?? Or any other tips? An alternative is not to reduce the dwgs to minimum size and have them all open stacked but with 6 or 7 dwgs open this has failings too. thanks for helping cheers andy Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 28, 2016 Share Posted January 28, 2016 Part of the problem may lie in the fact the program you are using was originally issued 14 years ago. In computing terms that is somewhat old. AutoCAD has evolved and in doing so there are features in new releases you don't have in 2002 and wouldn't be able to add unless you had access to the programming code which you don't. Maybe there is an add-on program that will give you the functionality you seek or another way of addressing the problem via a custom lisp routine. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted January 28, 2016 Share Posted January 28, 2016 This has been solved many times in a variety of ways. Let's start with something native to AutoCAD 2002. If I remember correctly, there is a menu called window that shows a list of open drawings. It was limited to nine drawings. Any more than that would require opening a window to see the entire list. Quote Link to comment Share on other sites More sharing options...
andybeedub Posted February 5, 2016 Author Share Posted February 5, 2016 Thanks that helps a lot, I feel a bit daft now not being able to find that myself! Quote Link to comment Share on other sites More sharing options...
squareknees Posted February 5, 2016 Share Posted February 5, 2016 I tend to tab through the drawings. It has been so long since I used 2002 I am not sure if you could do that back then. instead of minimizing the drawings I just have all of them open and when I want to go to another drawing I hit (ctrl & tab) it cycles through all of them in the order they were opened. I am the type that doesn't like to use the tabs at the top of the screen unless I have too. If I can type in what I want, I do it that way. I have a lot of short cuts in my express command alias editor. Hope this helps Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 5, 2016 Share Posted February 5, 2016 Robdraw Window is in 2016 and been there for a long time. squareknees are you opening one session of Autocad or multiple sessions ? There is a variable that sets this mode SDI 0 Quote Link to comment Share on other sites More sharing options...
squareknees Posted February 9, 2016 Share Posted February 9, 2016 Just a single session of AutoCAD Quote Link to comment Share on other sites More sharing options...
RobDraw Posted February 9, 2016 Share Posted February 9, 2016 Robdraw Window is in 2016 and been there for a long time. Yeah, but the OP is on 2002 and I haven't used menus in many years.. Quote Link to comment Share on other sites More sharing options...
