Results 1 to 3 of 3
    Full Member hcostanzo's Avatar
    hcostanzo's Computer Details
    Windows 7
    Civil
    hcostanzo's Discipline Details
    Civil
    worked in the Structural field for 5.5 years, now learning the ins and outs of civil work
    Civil 3D 2016
    Sep 2012
    Colorado, USA
    32
    Default Raster Image looks out of place but isn't
    Hello!
    I'm hoping someone knows a fix for this.
    I'm working on a large project, and I have 14000 feet of plan & profiles split into 500 ft sections, with a raster image as the background of all the plan views. The plan viewports are rotated 36 degrees using mvsetup.
    The problem is that when I go to any of the layout tabs to view my sheet the raster image appears to have shifted over, but when I plot the sheet the raster is in the correct spot and everything looks good.
    I would like to work within the layouts, but can't when the images appears out of place.
    Sorry for the long explanation, I just wanted to cover as much of the problem as I could.
    Any help is greatly appreciated, and thank you in advance!
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,728
    Try reloading your images in the xref manager. Command EXTERNALREFERENCES. Click the down arrow on the refresh button. I also have this problem occasionally with simple small pdf's. They max out the graphics memory after a lot of layout switching back and forth, so they don't get displayed just right. Reloading fixes it for me, but only for a while.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
    Windows 7
    Civil
    Civil
    Civil 3D 2016
    Sep 2012
    Colorado, USA
    32
    I tried Reload All References & I tried Reloading just the reference that is giving me trouble. No luck so far.
    Thank you for the idea though.
  1. Raster Image Help
    By AQucsaiJr in forum Autodesk Software General
    Last Post: 20th Aug 2010, 09:12 pm
  2. raster image
    By sidik in forum AutoCAD General
    Last Post: 23rd Mar 2009, 11:54 am
  3. Raster image
    By Bespoke in forum AutoCAD Beginners' Area
    Last Post: 11th Dec 2008, 10:39 am
  4. to draw vector lines on raster image (digitization from raster to vector)
    By cadamrao in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Jan 2008, 07:35 am
  5. raster image
    By Niz in forum AutoCAD Drawing Management & Output
    Last Post: 21st Jun 2006, 05:50 am
Tags for this Thread
