chubarka Posted January 31, 2016 Share Posted January 31, 2016 Will someone here help me out on this. I am obviously missing something basic here. I am attempting to get a polar array by indexing a circle 5 times this is the exact sequence that I am using: after drawing a 1" circle command line: ar, enter select object - select circle, enter enter type of array R P - P, enter specify center point of array - select center of circle enter number of items in array - 5, enter rotate arrayed object yes no y, enter this is the result Quote Link to comment Share on other sites More sharing options...
Cad64 Posted January 31, 2016 Share Posted January 31, 2016 You're using an older version of Autocad, so the command sequence is different from mine, but try this. ar, enter select object - (select the line that you want to array), enter enter type of array R P - P, enter specify center point of array - select center of circle enter number of items in array - 5, enter rotate arrayed object yes no y, enter Also, I believe you have left out an option that appears at the command prompt after "Number of Items", which is "Angle to Fill". This should be set to 360 if you want to array all the way around the circle. Quote Link to comment Share on other sites More sharing options...
chubarka Posted February 1, 2016 Author Share Posted February 1, 2016 Thank you so much Cad64! Quote Link to comment Share on other sites More sharing options...
