sivapathasunderam Posted February 3, 2016 Share Posted February 3, 2016 Dear all; I was learning civil3d Label the intersection points in cross section as shown in image 1.) Is that possible with civil 3d 2.) How to Create? Image shown is done by Simple AutoCAD many thanks Siva Quote Link to comment Share on other sites More sharing options...
BlackBox Posted February 3, 2016 Share Posted February 3, 2016 Yes, this is possible - consider the ADDSECTIONVIEWOFFELEVLBL Command. Cheers Quote Link to comment Share on other sites More sharing options...
sivapathasunderam Posted February 4, 2016 Author Share Posted February 4, 2016 BlackBox; Thanks for the response Siva Quote Link to comment Share on other sites More sharing options...
BlackBox Posted February 4, 2016 Share Posted February 4, 2016 You're welcome, Siva. While certainly not perfect, the Civil 3D development team has done a very good job of making *most* object-specific functionality contextual - by that I mean, you first select the object (in your example, a Section View), and you'll find specific functionality is provided in both the context (right click) menu, and the contextual Ribbon Tab. As another example, this is one of the many reasons that most are not even aware that Pressure Pipes can be edited from the Profile View, as they must first add a given Pressure Network to a Profile View, and select a Pressure Pipe before this functionality is made available, etc. In any event... Good luck, and Cheers! Quote Link to comment Share on other sites More sharing options...
