Results 1 to 6 of 6
    Forum Newbie
    AutoCAD 2016
    Feb 2016
    2
    Default Scale dimensions
    Please give me some keywords to solve the following:
    I'm using Autocad 2016, and drawing the bluepirnts of a house. Everything is measured in meters, so the unit is set to meter. The plan will be used later to construct a scale model of the house. 1/150th scale model of the original.
    What I would need:
    During drawing I'd like to "switch" the whole drawing to 150 times smaller, so all dimensions will be at the size of my scale model where I can measure or edit and then go back to the original size.
    Now I'm making a copy of everithing to a new file and scale it down by the suitable factor to get the 150 times smaller sizes that will fit to my later model.
    It is not a powerful way, everytime I change something in my original drawing I need to make a new copy and scale it down again.
    I hope autocad has a function for this, I've read about associative dimensions but I found it's not what I need. (or just I didn't understand it well)
    thank you for any ideas
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,729
    It sounds like you are doing everything in model space when you should be making use of paper space layouts and viewports.
    Attach a copy of the drawing you have thus far to your next post and someone here will take a look at it.
    Super Member Pablo Ferral's Avatar
    Inventor 2010
    Feb 2005
    London
    679
    Don't change the drawing - Change the dimensions!
    Draw at 1:1 scale. In order to get your 1/50 scale dimensions create a new dimension style with the value set to 0.02 (I'm on my phone right now, so I can't show you how this is done - sorry).
    Put each dimension style on its own layer so that you can make use of layouts and viewports to show the 1:1 dimensioned drawing and the 1/50 scaled drawing on the same sheet if paper.
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,148
    Like pablo Modify Dimension style "Primary units" "scale" 0.02 as you dim it will convert by this factor.
  5. #5
    Senior Member
    danellis's Computer Details
    Windows 7
    Dell Precision T1650
    Architecture 2014
    Dec 2010
    308
    If it were me I'd probably use the "alternative units" in the dimension style. That way you'd have the real-world value above the line, and the scaled distance below it.
    dJE
  6. #6
    Forum Newbie
    AutoCAD 2016
    Feb 2016
    2
    Thank you for all your ideas.
    Pablo's answer really solved the problem. Exactly that's what I needed.
  1. SCALE routine to explode and scale dimensions...
    By lamensterms in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st May 2014, 02:17 am
  2. Dimensions at 1:2 scale
    By beeb in forum AutoCAD Beginners' Area
    Last Post: 8th Dec 2009, 05:45 am
  3. Dimensions/Scale/Help
    By shellb in forum AutoCAD Beginners' Area
    Last Post: 1st Nov 2007, 10:16 pm
  4. scale/dimensions
    By eddie57 in forum AutoCAD Beginners' Area
    Last Post: 27th Dec 2005, 08:15 pm
  5. Dimensions don't scale to Viewport scale
    By brooksn in forum AutoCAD Drawing Management & Output
    Last Post: 6th Jul 2005, 06:18 pm
Tags for this Thread
