Tracker of using lisp file as xls in AutoCAD interface
kite15
Hi,
I am looking for a code by which i can save a "AutolispUsingRecord.xls" file.
Please, suggest by code or process step by step. I am the beginner on this things.
Needs:
1) Only Lisp related command to be listed into the xls file.
2) While save a drawing file a data will update into the said xls file automatically.
3) The count of the said command to be enlisted.
Please help if any script any....:cry:
Why would it be necessary to track this type of information? Why not just use a keylogger that is activated when an AutoCAD session is started?
Thanks.....
Lee Mac,
As i am beginner on this things can not getting any result after using the Lisp
Please, suggest/instruct as step by step for the same.
ReMark,
Mainly some user not saying real truth, that these are helping them......So, want to find out the real fact...:(
Thanks.
Have you saved your drawing?
As noted on my site in bold:
The CSV Log files are only written when the drawing is saved; this ensures there is no impact on performance whilst the user is working on the drawing.
Please read the program description on my site for a full understanding of how the program operates.
Its Work. Thank you very much.:o.:D
Hello Lee Mac,
The csv file is saving as "Log_date.."
Can you please guide how to save it "Username_Date.."
Or
The Folder name will be LISP-Logs_Username => ..........as existing..
Thanks in advance for more help!:unsure:
Change line 99 from:
                filename  (strcat directory "\\Log_" (LM:Date "YYYYMODD") ".csv")
to:
                filename  (strcat directory "\\" (getvar 'loginname) "_" (LM:Date "YYYYMODD") ".csv")
  • 5 months later...
Hello Lee Mac,
Can you please, advice for more update...
Actully looking for monthly basis record
i.e.: the date format will enter in the contain of csv file and the main csv file will be save as like June_2016 or June_2015 etc..:?
Thanks
Hello kite15 and welcome to the best cad forum, hands-down on the planet. Lots of us fully understand the "just starting out" part and as someone who only started real LISP coding less than 5 years ago I can tell you that it takes practice, practice, practice and then even more practice. It also involves lots of reading, studying, experimenting and then more practice. There's always plenty of help here and many other forums around the Internet, but nothing beats self-tutoring.
