Trevit Posted February 8, 2016 Share Posted February 8, 2016 Not done much AutoCAD for a while, but have a need to come back ot it now. Does anyone know if it's possible to redefine a block in a drawing with one from a webpage? For example it's possible to insert the file that is here: http://www.arcat.com/details/mielepro/11600108.dwg using the -INSERT command: Command: -insert Enter block name or [?] : http://www.arcat.com/details/mielepro/11600108.dwg But if I try redefining an existing block in a drawing, I get an 'invalid filename' error: Command: -INSERT Enter block name or [?] : Sink01=http://www.arcat.com/details/mielepro/11600108.dwg Block "Sink01" already exists. Redefine it? [Yes/No] : y *Invalid* Any help much appreciated. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted February 8, 2016 Share Posted February 8, 2016 My guess is that the block was created with a newer version of AutoCAD than the one you are using. Can you open the block file? Quote Link to comment Share on other sites More sharing options...
Trevit Posted February 8, 2016 Author Share Posted February 8, 2016 (edited) Yes. This works fine: Command: -insert Enter block name or [?] : http://www.arcat.com/details/mielepro/11600108.dwg Can you let me know if this works for you... Command: -INSERT Enter block name or [?] : NameOfAnExistingBLockInCurrentDrawing=http://www.arcat.com/details/mielepro/11600108.dwg Block "NameOfAnExistingBLockInCurrentDrawing" already exists. Redefine it? [Yes/No] : y Edited February 8, 2016 by Trevit Quote Link to comment Share on other sites More sharing options...
RobDraw Posted February 8, 2016 Share Posted February 8, 2016 Sorry, but I misunderstood your OP. I won't try what you are suggesting. I don't know if it is even possible to insert a block using a link. If it is, I would need to be absolutely certain the block is safe. Quote Link to comment Share on other sites More sharing options...
Trevit Posted February 8, 2016 Author Share Posted February 8, 2016 After some more digging I reckon I'll have to download the file first using vla-GetRemoteFile: http://forums.augi.com/archive/index.php/t-127623.html and then insert it. Quote Link to comment Share on other sites More sharing options...
jagwinn Posted February 21, 2016 Share Posted February 21, 2016 Download and open the drawing in your AutoCAD; Open the drawing you are wanting to insert the block into; Open DESIGN CENTER; In Design Center open the downloaded drawing and click on BLOCKS; Find the block you want and drag it into the target drawing (the drawing you want to use it in); You can then modify and wblock a new rendition of what you desire in this block; Name it something different, then purge the original block out of the drawing. John Quote Link to comment Share on other sites More sharing options...
