Correct me if I am wrong
I guess your Excel file perhaps looks like this:
PointName1
X1 Y1 Z1
PointName2
X2 Y2 Z2
etc.
Fatty
~'J'~
Hi, I hope someone can help, I'm not a lisp expert, but do a little VBA, so I'd like help with that if possible... I work as a land surveyor, I am using Autocad 2006 3D Map. I have a lot of occasions where I have lists of coordinates that need to be inserted as blocks in Autocad. The form of the list is point name, XYZ, the blocks are already defined, the point name goes in as an attribute of the block.
I'd like a vba routine where I select the points in excel, select my block from a directory where I store my blocks using the insert block routine already in autocad, scale etc, then ask autocad to insert these positions.... nothing to it hey... i'd be greatful for any help.
PointName1
X1 Y1 Z1
PointName2
X2 Y2 Z2
etc.
Fatty
~'J'~
It is 4 columns... Pointname,x,y,z.
Thanks
Put this code into desired sheet where stored your data
You need select all the four cells in the certain row and then
immediately click right mouse button
Change all to your suit: block name and tags
Works slowly, be patience
HTH
FattyCode:Option Explicit Dim pnum As String, x As String, y As String, z As String Dim acApp As AcadApplication Dim acDoc As AcadDocument Dim acSpace As AcadBlock Dim acdCap As String, ExcCap As String Private Declare Function SetFocus Lib "user32" (ByVal hwnd As Long) As Long Private Sub Worksheet_BeforeRightClick(ByVal Target As Range, Cancel As Boolean) If Target.Columns.Count = 4 And Target.Rows.Count = 1 Then Dim rng As Range, lCell As Range Dim rCnt As Long, cCnt As Long ActiveCell.EntireRow.Select Set rng = Application.Selection pnum = rng.Cells(1, 1) x = rng.Cells(1, 2) y = rng.Cells(1, 3) z = rng.Cells(1, 4) Call GoAcad Cancel = True Else MsgBox "Wrong cell double clicked" Cancel = True End If End Sub Private Sub GoAcad() On Error GoTo Err_Control ExcCap = Application.Caption Dim bName As String, fn As String bName = "POINT" fn = GetFilePath Set acApp = CreateObject("Autocad.Application") acApp.Visible = True acApp.WindowState = acMax Set acDoc = acApp.Documents.Open(fn, False) acDoc.Activate Set acDoc = acApp.ActiveDocument SetFocus acDoc.hwnd If acDoc.GetVariable("CVPORT") = 1 Then Set acSpace = acDoc.PaperSpace Else Set acSpace = acDoc.ModelSpace End If Dim oblkRef As AcadBlockReference Dim ipt(2) As Double ipt(0) = CDbl(x): ipt(0) = CDbl(y): ipt(0) = CDbl(z) Set oblkRef = acSpace.InsertBlock(ipt, bName, 1, 1, 1, 0) Dim attVar As Variant Dim acnt As Integer attVar = oblkRef.GetAttributes For acnt = 0 To UBound(attVar) Select Case UCase(attVar(acnt).TagString) Case Is = "POINTNUMBER" attVar(acnt).TextString = pnum Case Is = "X" attVar(acnt).TextString = x Case Is = "Y" attVar(acnt).TextString = y Case Is = "Z" attVar(acnt).TextString = z End Select Next DoEvents acDoc.SaveAs (fn) acApp.Quit Set adoc = Nothing Set acApp = Nothing AppActivate ExcCap, True 'AppActivate Application.ExcCap SetFocus Application.hwnd '' back to Excel Err_Control: If Err.Number = 0 Then MsgBox "Insertion was successful" Else MsgBox Err.Description End If End Sub '' forget about where I stealed this function Public Function GetFilePath() As String 'Declare a variable as a FileDialog object. Dim fd As FileDialog 'Declare a variable as a file name string. Dim fn As String 'Create a FileDialog object as a File Picker dialog box. Set fd = Application.FileDialog(msoFileDialogFilePicker) 'Declare a variable to contain the path 'of each selected item. Even though the path is a String, 'the variable must be a Variant because For Each...Next 'routines only work with Variants and Objects. Dim vrtSelectedItem As Variant 'Use a With...End With block to reference the FileDialog object. With fd 'Allow the selection of single file. .AllowMultiSelect = False 'Use the Show method to display the File Picker dialog box and return the user's action. 'The user pressed the action button. If .Show = -1 Then 'Step through each string in the FileDialogSelectedItems collection For Each vrtSelectedItem In .SelectedItems 'vrtSelectedItem is a String that contains the path of each selected item. 'You can use any file I/O functions that you want to work with this path. 'This example simply displays the path in a message box. fn = vrtSelectedItem Next vrtSelectedItem 'The user pressed Cancel. Else End If End With 'Set the object variable to Nothing. Set fd = Nothing GetFilePath = fn End Function
~'J'~
Wow, thanks for all that code I appreciate it.. I've inserted the code into a module in excel, but when I try to run it nothing happens.... I'm I doing something stupid....
Sorry for the late answer
I was not at home yesterday
Let you send me test message on my address:
fattyhallex@gmail.com
I'll send you sample Exctl and Acad files
~'J'~
Try this one, I haven't understood exactly
what you need earlier, hope this will be work better for you
Change block name, tags and reference to your current
Acad version
Fatty
~'J'~
hi fatty,
what if you had a fourth line to define different codes which would represent different blocks or linetypes like the following:
1, point number,
2, X
3, Y
4, Z
5, code
For example, if i was surveying a fence, and had the code F001, I would need to gather several points with the same code to represent the fence, I would then want to join all these points with the same codes together. and then carry on with other codes e.g F002, F003 etc.. (or KB001 or TR001 tree block for example) to represent a kerb...codes I guess would have to be user defineable from the start. The above would all have to have their respective layers also.
could you modify the above code to include that?
