Objects appear in model space only
Hobblenobble
I have a drawing of a site map with houses, roads and an ordanance survey grid. They each have their own layer. These are all appear in model space. However, within a viewport in paperspace, the ordanance objects are hidden some way. I dont know how this is done, but would like to. It looks like there is a filter on the layers but that is as far as I can understand it. Thank you.
The layers may be marked to not show in certain viewports. With a viewport active, AKA current, (double click inside it) open the layer manager and look in the columns of the layer manager referencing viewports to see if any are turned off, frozen, or locked in that particular viewport. Repeat for the other viewports.
When you open the layer manager that way, the changes only effect the current viewport.
