Poly line selection problem
oceanicanu
recently i have selecting poly line it shows some symbol,these symbols are disturbing the poly line selection.kindly please check the attachment for more info.
It looks like you are not in a command. If that is so, I don't think it is a cursor badge that is controlled by the CURSORBADGE variable. I'm thinking it might be indicating constraints. Can you get a better screenshot of it?
I find it funny that you've got the properties preview box turned on but you find that tiny icon disturbing.
It looks to me like OP is hovering over something with constraints applied.
Run the DELCON command and select those objects and then when the command is done, hover over the polyline again.
Hi swain
Thank you for your effort.command is working properly.
Regards
Anu
