andrew_ysk Posted February 11, 2016 Share Posted February 11, 2016 i need to use autocad to calculate out (so that i can print out 1: 1 scale) an resulting ellipse holes of a solid 12cm rod going thru a hollow sheet metal at an angle of 30 deg c and 45 deg c. i almost pulled off all my hair just trying to draw that stupid thing out. can someone teach me step by step. i never really taught of using 3d modelling of autocad, only learn it myself, but apparently not enough for work. i draw a simple pic of how the assemble is.. but it is the resulting elipse hole that i need to print out. thanks. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 16, 2016 Share Posted February 16, 2016 You might take an approach similar to this. I used a surface for my sheet metal and a solid for my rods. The first image was created using a 2D wireframe visual style. Here is the same image created using a Conceptual visual style. Red = centerline Magenta = 30 deg cylinder Green = 90 deg cylinder Cyan = 45 deg cylinder Created surface, added cylinders, rotated two of the cylinders (30 deg & 45 deg) subtracted cylinders from surface, exploded resultant surface to arrive at final solution containing two ellipses and one circle. Use Area command to obtain area. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 16, 2016 Share Posted February 16, 2016 The result of a solid cylinder subtracted from another solid. Quote Link to comment Share on other sites More sharing options...
tzframpton Posted February 16, 2016 Share Posted February 16, 2016 Good example ReMark. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 16, 2016 Share Posted February 16, 2016 Thanks stranger. Quote Link to comment Share on other sites More sharing options...
tzframpton Posted February 16, 2016 Share Posted February 16, 2016 I still lurk daily on the AutoCAD side. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 16, 2016 Share Posted February 16, 2016 Come over for a taste of the dark side? In April I'll be lurking in San Antonio. Quote Link to comment Share on other sites More sharing options...
tzframpton Posted February 16, 2016 Share Posted February 16, 2016 If you're driving, make a quick bend around to Dallas and enjoy some smoked pork and a beer on the patio. Quote Link to comment Share on other sites More sharing options...
paulmcz Posted February 16, 2016 Share Posted February 16, 2016 If you want to use autocad to calculate the resulting ellipse, as you said, to find longer radius of the ellipse, for 30° angle, type this on command line: (/ (/ 12.0 (sin (/ (* 30 pi) 180))) 2) for 45° angle type: (/ (/ 12.0 (sin (/ (* 45 pi) 180))) 2) The shorter radius will of course be 6 in both cases. Quote Link to comment Share on other sites More sharing options...
