Results 1 to 3 of 3
    Forum Newbie
    Civil
    T_Scheck's Discipline Details
    Project Engineer
    Civil
    Civil 3D 2014
    Feb 2016
    Columbus, OH
    1
    Default Display spot elevations but not contours in viewport
    I have a couple of viewports where I just want to show spot elevations of my surface and not the contours. Whenever I freeze the contours my spot elevations disappear too. When I select a spot elevation it's layer shows as "C-TOPO-TEXT" and when I right-click and go to "Edit Label Style" the label layer is "GRADE-P-T". When I select my contour lines they are on a "C-TOPO" layer, and then when I go to "Edit Surface Style", "Display" tab it shows that the major and minor contours are on "CONTMJR-P-L" and "CONTMNR-P-L" layers respectively. My point being that it seems like they are all on different layers, so I would think I could freeze/thaw the two interchangeably. What am I missing?
    Thanks ahead of time!
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,706
    If the spot elevs are cogo points then use a point lable style this is independent of contour styles.
    How are you making the spot elevations.
    I have a lisp to label 1 or more individual cogo points as text.
    Senior Member MillerMG's Avatar
    MillerMG's Computer Details
    Windows 7
    OPTIPLEX 3020
    Intel(R) Core(TM) i5-4570 CPU @ 3.30GHz
    8.0 GB
    The two in front of me. Dude, I got Dell's
    Civil
    MillerMG's Discipline Details
    CADD Drafter
    Civil
    Civil 3D 2017
    May 2014
    Fredericksburg, VA
    449
    I bet that the LISP that BIGAL talked about would be really helpful!
  1. Spot Elevations - Corridor Surface
    By mjpconnor in forum Civil 3D & LDD
    Last Post: 18th Aug 2014, 03:43 pm
  2. Corridor surface spot elevations
    By Cardinal in forum Civil 3D & LDD
    Last Post: 6th Jun 2012, 04:33 pm
  3. Assign Elevations to Contours from an ESRI Shape File
    By Openantics in forum Civil 3D & LDD
    Last Post: 14th Jun 2011, 08:28 pm
  4. Plotting contours from randoml placed spot levels
    By JamesP in forum AutoCAD Beginners' Area
    Last Post: 13th Jun 2009, 02:56 pm
  5. mesh from 3D spot elevations...
    By hazardman in forum AutoCAD Drawing Management & Output
    Last Post: 19th Dec 2007, 07:44 pm
Tags for this Thread
