Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Full Member
    AutoCAD 2012
    Feb 2009
    32
    Default strange result with DCL external values from multiple txt files
    I know how to do this and have done it. BUT.
    I have multiple products.ini, products2.ini files where i get the values for popup_list.
    The first selected is ok. However when i change to the external ini file to the next ini file. The content of the popup_list is still the one i have used at first.
    I cant post the whole lisp nor DCL but has someone experienced this before and how can i "flush" the old external ini values?
    Thanks.
    Super Member rlx's Avatar
    rlx's Computer Details
    W10
    i74ghz/ssd500/2tbhdd
    Electrical
    rlx's Discipline Details
    electrical designer dragon
    Electrical
    I dont excel in anything but I rearly give up
    AutoCAD 2016
    Nov 2014
    Bergen op Zoom , Netherlands
    1,068
    Quote Originally Posted by Apache2k View Post
    Thanks.
    Make shure you refresh your dialog each time you start it. When loading your ini , first set the old ini's to nil. I suppose you use a list to fill your popup list , so upon load , first set this list to nil also. Try to make a function to reset all viariables and lists whenever you load a new ini. And last but not least , have a critical look that variable are declared properly , global / local.
    gr. Rlx
    Full Member
    AutoCAD 2012
    Feb 2009
    32
    Thanks for the quick reply.
    I did reset the values. It is there. Its one function doing all of it and idid use (setq prod nil)
    Still no luck. Im turning blue
    Is there a reset for the internal lists or something similar in lisp?
    W10
    Electrical
    Electrical
    AutoCAD 2016
    Nov 2014
    1,068
    I have posted serverall dcl related routines on this forum , just search for rlx and maybe you find something of use. My personal experience for this kind of errors , which I frequently have my self , is what I call sloppy programming , I start out with a good strategy , but then I change something and forget or fail to see the impact on other parts. Use breakpoints in your editor and check each step. If for example you have a routine to fill your popup list and have declared this list local , then trying to change it in another part of your program will have no effect. Unless your pc is bewitched and you can blame your wife or girlfriend (usually the case) , there must be a logical error in your program/ thinking. You could go old school and make a special variable dump routine that prints your variables at certain points in your app , thus confirming each step. But if its any comfort , I know exacly how frustrated it can be when a bug is eating your brain ;-). If nothing helps , post or mail the part that's bugs you.
    Gr.Rlx
  5. #5
    Full Member
    AutoCAD 2012
    Feb 2009
    32
    Thanks Rlx
    Its what i did try to avoid, so lets split it in to parts and check
    Ill inform the result.
  6. #6
    Senior Member
    Civil
    Hippe013's Discipline Details
    Survey Crew Chief / Civil Designer
    Civil
    Land Survey / Civil Engineering
    Civil 3D 2017
    Feb 2010
    North Dakota
    385
    How are you opening and reading your .ini files?
  7. #7
    Full Member
    AutoCAD 2012
    Feb 2009
    32
    Like this:
    (setq produfile (findfile ininame1))
    (open produfile "r")
  8. #8
    Senior Member
    Civil
    Civil
    Civil 3D 2017
    Feb 2010
    North Dakota
    385
    Are you then closing it with the following?
    Code:
    (close produfile)
  9. #9
    Full Member
    AutoCAD 2012
    Feb 2009
    32
    Yes Its closed. Forgot to mention. I hate bugs found so many bugs but none of them fixed this issue. Still fixing/searching.
  10. #10
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2017
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,249
    Hi,
    The action_tile that selects the file should have the codes to retrieve the contents of the new selected file then the variable that holds the strings must be set to nil prior appending strings to it.
  1. Using multiple external data tables.
    By Don Mitchell in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Nov 2014, 08:31 pm
  2. multiple external polygon offset
    By ctdlc888 in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Aug 2012, 01:43 pm
  3. Replies: 6
    Last Post: 20th Sep 2011, 07:39 am
  4. Layers and external reference files
    By Nardino in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 30th Jun 2010, 03:18 pm
  5. Links to external files
    By Vinnt1974 in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Mar 2004, 02:59 pm
Tags for this Thread
