Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
    Senior Member martinle's Avatar
    martinle's Computer Details
    windows 10
    AutoCAD 2018
    Mar 2010
    Austria
    168
    Default connected polylines corners
    Hello
    Please help!
    I can not lisp.
    Seeking a way with a lisp to connect the corners of a closed polyline.
    These polylines are always so similar to the example.
    There are very many such lines and it would be great if you could solve with a lisp.
    Thank you!
    Martin
    My friend has the Google Translator
    Senior Member
    Stefan BMR's Computer Details
    Win10
    Structural
    AutoCAD 2019
    Sep 2011
    Baia Mare, Romania
    392
    Hi Martin
    Try this, but be aware that it will fail if there are duplicate points or if any partial distance is shorter that the "offset" distance.
    Code:
    (defun connect (e / _point d d1 l p1 p2 a b n i)
      (setq _point vlax-curve-getpointatparam
            d (vlax-curve-getdistatparam e (setq n (fix (+ 0.1 (vlax-curve-getendparam e))))))
      (repeat (setq i (1+ n))
        (setq l (cons (setq p1 (_point e (setq i (1- i)))) l))
        (if
          (setq p2 (cadr l))
          (if
            (and
              (< (setq d1 (distance p1 p2)) d)
              (not (zerop d1))
            (setq
              d d1
              a (rem (1+ i) n)
              b i
      (mapcar 'set '(a b) (list (max a b) (min a b)))
      (while
          (setq a (rem (1+ a) n))
          (setq b (rem (+ n (1- b)) n))
          (not (= (rem (1+ a) n) b))
        (entmake
          (list
            '(0 . "LINE")
            (cons 10 (_point e a))
            (cons 11 (_point e b))
    (defun c:test (/ ss i)
      (if
        (setq ss (ssget '((0 . "LWPOLYLINE"))))
          (connect (ssname ss (setq i (1- i))))
    windows 10
    AutoCAD 2018
    Mar 2010
    Austria
    168
    Hello Stefan!
    That's awesome !!
    Many thanks.
    It works wonderfully!
    Thank you!
    Martin
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,146
    Just in case you would like an alternative which does not use lisp, draw a polyline at the centre, give it a width, and turn Fill off. The effect is the same
  5. #5
    windows 10
    AutoCAD 2018
    Mar 2010
    Austria
    168
    Hi Eldon
    My polylines exist already.
    Only the corner joints are still missing.
    thank you
    Martin
  6. #6
    Senior Member
    Win10
    Structural
    AutoCAD 2019
    Sep 2011
    Baia Mare, Romania
    392
    You're welcome Martin
    Duplicate points bug removed
    Code:
    (defun connect (e / _point d d1 p1 p2 p11 p12 p21 p22 a b n i)
        (if p2
          (if
            (and
              (not (zerop d1))
            (setq
              d d1
              a (rem (1+ i) n)
              b i
        (setq p2 p1)
      (if (zerop b) (mapcar 'set '(a b) (list b a)))
      (setq p11 (_point e a)
            p21 (_point e b)
      (while
          (while
            (equal p11 (setq p12 (_point e (setq a (rem (1+ a) n)))) 1e-8)
          (while
            (equal p21 (setq p22 (_point e (setq b (rem (+ n (1- b)) n)))) 1e-8)
          (not
            (or
              (= (abs (- a b)) 1)
              (= (abs (- a b)) n)
        (entmake
          (list
            '(0 . "LINE")
            (cons 10 (setq p11 p12))
            (cons 11 (setq p21 p22))
      (if
  7. #7
    windows 10
    AutoCAD 2018
    Mar 2010
    Austria
    168
    Hello Stefan!
    Many thanks.
    Thank you!
    Martin
  8. #8
    windows 10
    AutoCAD 2018
    Mar 2010
    Austria
    168
    Hello Stefan,
    One small thing is I have noticed.
    There are drawn all the oblique connections.
    But also a connection to the straight end of the polyline.
    Would it still possible that you will not use it to create any line on the other is?
    That would be great!
    Many thanks!
    Martin
  9. #9
    windows 10
    AutoCAD 2018
    Mar 2010
    Austria
    168
    sorry for my bad English
  10. #10
    Senior Member
    Win10
    Structural
    AutoCAD 2019
    Sep 2011
    Baia Mare, Romania
    392
    Updated previous post.
    I'm not sure I have covered all the possibilities, I will check again later.
  1. conduit connectors shown as 'not connected'
    By Ravenstown in forum MEP
    Last Post: 18th Jan 2014, 12:52 pm
  2. Join two connected solid hatches
    By satishrajdev in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th Nov 2012, 04:45 pm
  3. Two Polylines Not Joining at corners
    By CadDan in forum AutoCAD Beginners' Area
    Last Post: 27th Jul 2009, 07:43 pm
  4. Making Sure Lines Are Truly Connected
    By Shanna in forum AutoCAD General
    Last Post: 24th Oct 2007, 02:21 am
  5. Thick polylines don't appear to join at the corners
    By cjhornet in forum AutoCAD Drawing Management & Output
    Last Post: 7th Jul 2007, 11:05 am
