Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Forum Newbie
    AutoCAD 2013
    Feb 2016
    6
    Default millimeter coordinates to meter coordinates (dimension distorted)
    there where a thread from 2011 that suggest to do as above to scale the whole drawing and keeping the base point to 0,0 which is great but all my dimensions got distorted to a meaningless very big scale , is it a dimension issue like the dimension when created was non associative or what , can i fix it or is there is a lisp for that, thanks.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Did you use a metric template when you started this drawing?
    Forum Newbie
    AutoCAD 2013
    Feb 2016
    6
    I don't know as the drawing was created by a consulting office i just received it as i described.
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    Post the dwg sounds like the dimstyle may be the problem check your dim style and do a DIM update check also Dimscale.
  5. #5
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,147
    The easiest way to use such a drawing is if you xref it with the appropriate scale factor into a new blank drawing.
    If you want to use the drawing itself by scaling, you will also have to go into any Dimension styles and manually alter the Fit.
    But if you post part of such a drawing, then you could be given explicit instructions.
  6. #6
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,147
    This is what happens when I scale a drawing in mm with dimensions not associative.
  7. #7
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    Why not just change the UNITS setting?
    Drafting is a breeze.
  8. #8
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    I answered in the other thread, use -dwgunits to set to meters from millimeters.
  9. #9
    Forum Newbie
    AutoCAD 2013
    Feb 2016
    6
    yes thank you SLW210 this converted the drawing but still the coordinates still in mm and the dimensions also.
  10. #10
    Forum Newbie
    AutoCAD 2013
    Feb 2016
    6
    oh thanks it worked i figured it out , its hilarious , the dwg units in feet as shown when type units but the consultant was meaning to work as mm , so when i use -dwgunits to convert it to mm without scaling as it is an error its ok , then i used the command again to change the units to m but this time with scaling and voila , the dimensions and coordinates are in m but the dimension distorted due to scaling as the drawing was fault from the beginning , so can i do any thing then when the drawing is scaled from mm to m the dimensions (arrows , lines extra) is scaled proportionally from dim update or dim scale
  1. Millimeter coordinates to meter coordinates?
    By risberg in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 23rd Feb 2016, 02:07 pm
  2. Need help about coordinates
    By sabregod in forum AutoCAD Drawing Management & Output
    Last Post: 4th Jun 2015, 03:27 am
  3. Lisp for getting Area into square meter and square millimeter
    By rengised in forum AutoLISP, Visual LISP & DCL
    Last Post: 27th Aug 2013, 06:46 pm
  4. Convert mouse coordinates to drawing coordinates
    By M76 in forum .NET, ObjectARX & VBA
    Last Post: 26th Aug 2011, 12:07 pm
  5. meter or millimeter
    By renzon in forum AutoCAD 3D Modelling & Rendering
    Last Post: 24th Jul 2007, 11:55 am
