Corridor Disappearing!!!!
JerryG
Having a problem where my Main Corridor in my Xref
is Disappearing in my drawing that the Xref is linked to. (shows up fine in the Xref itself)
This is happening in any Drawings that the Xref is in.
The Xref has Multiple Corridors in it witch all show up fine in my drawing.
Everything in the Xref also shows up fine except for the main Corridor
which does not show up at all. The Corridor in question will show up if I detach and reload the Xref however once I regen it goes away.
This is what I have Tried so far.
1.Saved the drawing and Xref as different names then Attached the Newly named
Xref again - no change.
2. Made sure everything was turned on in the Corridor Style - No change
3. Ran an Audit, Recover and Purge on the Xref and Drawing - No change
4. Completely detached all Xrefs in the drawing Closed AutoCAD - rebooted computer then Reloaded Xref - No change :x
Changed "Type" to "Overlay" - No change, so changed it back to "Attach"
Xref and drawing settings:
Indexctl is 3
Demand load is 3
Annoallvisable set to 1
Visretain 1
Display - General - all on - No change.
Anything else anyone can think of to try????? :unsure:
Ok so I changed the code set style hoping that there was some setting in there keeping the
corridor from showing up but it did not change. Im stumped!
This is a really stupid idea but is the main corridor layer turned off? I am almost 100% sure that you have already checked this but I have had this happen to me as well. Also for some odd reason is the style for the corridor properties display tab turned on?
Yes that was my first thought to. Just to make sure I even placed the corridor on a completely
new layer. Looked at the Display tab also and it is on.
Ive also changed the corridor style completely. When I open the drawing for the first time or
reload the xref I see the corridor just fine
but as soon as I regen it goes away????????
Whats really odd is I have 6 intersections in the drawing that are
on the same corridor style and they show up just fine.
This is pretty much how I feel right now about your last post........................................... I am at a loss for words. I have no idea what else could possibly be preventing one object that is the exact same as the others from showing up in your drawing. This is a horrible idea but maybe try not using it as a xref?
  • 5 weeks later...
Ok - Fixed!!!
It took one of my coworkers looking over my shoulder and suggesting things I
had not thought of. Matt B gets credit for the fix!
So what it was is the "Rebuild automatic" was checked on the corridor that was not showing up. For reasons I am still unclear about
it was causing the corridor to not show when xrefe'd into a drawing. What's odd though is I have over 7 different corridors in this xref and they were all checked "rebuild Automatic". It did not affect those just my main corridor. So we unchecked "rebuild Automatic"
in the Xref. Saved the drawing. Then reloaded and it works as it should now
Say What!?!?!?!?! That's awesome JerryG! Thanks for following up. That is very strange indeed. I would have never thought to look at that. Glad you got it all figured out! I just noticed I used a LOT of !!!!!!!!!!!!! hahahaha. My apologies.
You bet! Its one of those things I would have never thought of either
since it really should not have any control over the corridor in an xref.
I'd have to agree with you there Mr. Incredible. I have no idea why it would change the outcome of the xref. Autodesk probably isn't too sure either. haha
