Results 1 to 3 of 3
    Full Member
    Architecture 2012
    Jan 2012
    95
    Default Can I use the same project setup for both ACA and MEP?
    I have started a project for my house in Autocad Architecture. The plan is to make a drawing of my house in ACA and have every detail of the house in this project. This includes beside the architectural part even everything regarding ventilation, electrical, heating, plumbing etc.
    To my question:
    1. When I want to use Autocad MEP to make vent., el., heat., plumb., drawings is it “the right way” to use the same project I use in ACA or do I have to create a new one. If I can use the same project (it would be logical) then I guess I only need to create new constructs where I will draw my ventilation, heating system (separately of course) and use xref to import my floor levels, right?
    2. In ACA project I made separate constructs for each floor level. Do I need to make also separate constructs in MEP for each level or can I use one constructs to draw the whole ventilation system for the house? If I do it the same way like in ACA then I just wonder how the ventilation system will make the “connections” between levels if you understand what I mean.
    Jesus, I hope I was clear enough with my questions 
    Best regards to you all and of course thanks in advance,
    M
    Full Member
    KeithBrown's Computer Details
    Windows 10
    Need a minimum of 3 to work effectively!
    MEP 2016
    Jun 2012
    Chicago, IL, USA
    58
    1. You can place them in the same project. Just make sure that you use a MEP template when you are drawing your MEP systems.
    2. If its a small job you can place them in the same file but I would recommend placing them in separate files. This will allow your tags to elevate based on the level that the installer is standing on when installing the duct. For instance, if you use the same file for all levels, all elevations will be based off the 0 elevation of the drawing which will be the first floor and not necessarily the 2nd, 3rd, or basement level. There are ways around this with property sets but this is not for the beginner. MEP items will connect across xrefs if all drawings are brought into a 'view' drawing.
    Hope this helps.
    Full Member
    Architecture 2012
    Jan 2012
    95
    Copy that.
    Thank you KeithBrown!
    Quote Originally Posted by KeithBrown View Post
    Hope this helps.
  1. Replies: 3
    Last Post: 16th Mar 2015, 08:11 pm
  2. Replies: 4
    Last Post: 19th Mar 2013, 02:27 pm
  3. Page Setup Resets To Portrait from Landscape in Sheet Set Page Setup Overrides DWT
    By Kapanther in forum AutoCAD Drawing Management & Output
    Last Post: 30th Nov 2010, 12:31 am
  4. setup DIM
    By alijahed in forum AutoCAD General
    Last Post: 17th Nov 2009, 11:55 pm
  5. Project Properties - Item Numbering Setup
    By ziemerd in forum Electrical
    Last Post: 12th Jan 2009, 11:27 pm
