Results 1 to 6 of 6
    Full Member
    AutoCAD 2014
    Feb 2016
    59
    Default Lisp to convert Annotative TEXT to Annotative MTEXT
    Looking for lisp to convert Annotative TEXT to Annotative MTEXT while retaining its annotative scales. Thanks alot.
    Senior Member CAD USER's Avatar
    AutoCAD 2014
    Oct 2015
    100
    Full Member
    AutoCAD 2014
    Feb 2016
    59
    Quote Originally Posted by CAD USER View Post
    That did not work. It coverts to mtext but all its annotative scales are gone.
    The text is Annotative with various different scales. So The Lisp has to also retain its various Annotative scales & its location as well.
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,139
    If you have Express loaded, Text, Convert to Mtext
  5. #5
    Full Member
    AutoCAD 2014
    Feb 2016
    59
    Quote Originally Posted by BIGAL View Post
    That is the issue. It can be converted to mText but their annotative scales will be gone which I need to retain.
  6. #6
    Full Member
    AutoCAD 2014
    Feb 2016
    59
    hERE IS A PICTURE OF A ANNOTATIVE TEXT
    The text with the blue square is the annotative text in the current scale, the faded text around it is that SAME text but at different annotative scale.
    Can any lisp convert this annotative text to annotative MTEXT & retain its annotative scales & their respective location in the drawing.
    Hope this is clear to everyone.
    Thank You
  1. Annotative Block With Dynamic Properties - Rotation Issues at Annotative Scales
    By nwinslow in forum AutoCAD Drawing Management & Output
    Last Post: 7th Aug 2015, 07:34 am
  2. Annotative Mtext Dissappearing in Model Space
    By SMP in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 26th Jun 2012, 03:46 am
  3. Insert annotative block as non annotative dwg + trim object scalelist
    By Fnuik in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Dec 2010, 09:14 pm
  4. Convert text to mtext in lisp?
    By muck in forum AutoLISP, Visual LISP & DCL
    Last Post: 27th Jul 2010, 09:31 am
  5. Mtext no annotative printed to PDF from layout.
    By gomitell in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 18th May 2009, 04:00 pm
