Results 1 to 4 of 4
    Forum Newbie
    AutoCAD 2016
    Feb 2016
    3
    Default Is there a way to remove layers in bulk?
    I have a series of drawings that I am now in charge off and three or more people have worked on it. I have changed all of the layers on the drawing to my layers. but there is 50 or more layers from other people editing these drawings. is there any way to remove the layers at once or can I only remove them one at a time with LALDEL? I appreciate any help.
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,135
    PURGE command.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    Senior Member
    danellis's Computer Details
    Windows 7
    Dell Precision T1650
    Architecture 2014
    Dec 2010
    321
    You can delete multiple layers through LAYDEL
    Go into the command then type N for NAME. This will open a dialogue box with a list of layers. These day be selected using the normal Windows selection methods (shift at start and end of a selection set; control to add-remove individual items)
    Usual warning about being VERY CAREFUL when using laydel apply!!
    dJE
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    It can also be done through the layer manager. This method will not delete layers that are in use, similar to purge.
    Drafting is a breeze.
  1. Adding Layers to Drawings in Bulk
    By AIS Dan in forum AutoCAD Drawing Management & Output
    Last Post: 25th Apr 2012, 05:22 pm
  2. How do I remove unwanted blocks & layers?
    By eelywig in forum AutoCAD Drawing Management & Output
    Last Post: 4th Dec 2009, 07:43 pm
  3. Unable to remove some layers . . .
    By Dog in forum AutoCAD Drawing Management & Output
    Last Post: 15th Oct 2009, 01:33 pm
  4. How to remove corner radiuses in views; to remove confusing double lines in layout
    By nbaryosef in forum AutoCAD Drawing Management & Output
    Last Post: 17th Feb 2008, 12:06 am
  5. layers i cant remove
    By drahcir in forum AutoCAD Drawing Management & Output
    Last Post: 20th Oct 2006, 02:53 pm
Tags for this Thread
