MeGuinness Posted February 26, 2016 Share Posted February 26, 2016 I have started using AutoCAD for about one week so be gentle with me please Im creating a Rc car chassis ,I used a combinations of lines and polylines arc's and circle for the screws holes ..... I joined the lines all by converting the lines to polylines and using the JOIN command. I then switched to 3d for the extrude part....and gave a thickness of 5mm .. Â My question is how do I get to show as a solid image without all the lines ? Thanx Quote Link to comment Share on other sites More sharing options...
JD Mather Posted February 26, 2016 Share Posted February 26, 2016 Looks like a surface body, not a solid body. Attach your *.dwg file here and end all doubt. Â Once you get a solid body - the command you are looking for is shademode. Quote Link to comment Share on other sites More sharing options...
CC6614 Posted February 26, 2016 Share Posted February 26, 2016 It appears that your main body isn't a closed loop. You could go back before the extrude and try the region command. If that fails you know you don't have a closed loop. Your holes extruded correctly from what I can tell. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted February 26, 2016 Share Posted February 26, 2016 Extruding lines and polylines creates Surfaces. You should use the Presspull command to create Solids. https://www.google.com/?gws_rd=ssl#q=autocad+presspull Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 27, 2016 Share Posted February 27, 2016 When extruding lines, arcs and polylines in a closed shape using the PressPull command will result in a solid. Quote Link to comment Share on other sites More sharing options...
