extrude lines and polylines
MeGuinness
I have started using AutoCAD for about one week so be gentle with me please😀
Im creating a Rc car chassis ,I used a combinations of lines and polylines arc's and circle for the screws holes .....
I joined the lines all by converting the lines to polylines and using the JOIN command.
I then switched to 3d for the extrude part....and gave a thickness of 5mm ..
My question is how do I get to show as a solid image without all the lines ?
Thanx
Looks like a surface body, not a solid body.
Attach your *.dwg file here and end all doubt.
Once you get a solid body - the command you are looking for is shademode.
It appears that your main body isn't a closed loop. You could go back before the extrude and try the region command. If that fails you know you don't have a closed loop. Your holes extruded correctly from what I can tell.
