Results 1 to 6 of 6
    Senior Member Siberian's Avatar
    Siberian's Computer Details
    Windows 7
    Asus M4A785TD
    AMD X4 965
    16 GB
    295 GTX
    Samsung HD103UJ
    SyncMaster 2443
    MEP 2012
    Jul 2005
    Norway
    431
    Default Scale from meters to millimeters
    I recieved a drawing from an architect, but the drawings measurments were in meters, and I'm oh so used to millimeters. Let's say a line is 5000 mm in real life. On the drawing I would measure it to just 5. I didn't think it was a problem, I could just scale it up, but this resulted in a performance-drop making the drawing almost impossible to work with. Can I solve it some other way?
    Also, many lines in the drawing a clearly quite thick, but changing the thickness doesn't seem to have any effect, I can't get it to show the change in thickness no matter what. And yes, the LWT button is on.
    If at first you don't succeed - remove all evidence you ever tried.
    Forum Deity
    not specified
    Jul 2004
    Anchorage, Alaska
    2,074
    Scaling by 1000 to give millimeters versus meters should have insignificant or no affect on performance. Must be some other reason.
    ....well then turn LWT off
    maybe you need to set 'shademode' to '2d'?
    Windows 7
    Asus M4A785TD
    AMD X4 965
    16 GB
    295 GTX
    Samsung HD103UJ
    SyncMaster 2443
    MEP 2012
    Jul 2005
    Norway
    431
    The lineweight doesn't change, regardless of LWT. But that's a minor problem. I managed to fix the performance bit by exploding the drawing once.
    Full Member
    not specified
    Mar 2006
    26
    Try changing the overall LTSCALE. If there are many linetypes it could effect the drawing performance.
  5. #5
    Full Member Ferdinand's Avatar
    AutoCAD 2004
    Oct 2006
    Czech republic
    38
    Format - Units - ...
  6. #6
    Senior Member
    Architectural DT 2005
    Sep 2006
    334
    Smile
    best way is to just go ->command,-> scale -> select your objects (remember to have all your layers on and unfrozen), -> specify your basepoint as 0,0
    ->scalefactor: would be 1000
    thats you to millimetres....
    you may need to adjust your dimension style to mm so everything is back to mm.
    this as suggested above......shouldnt really affect line thicknesses, or performance....
    thats it!
  1. understanding drawing scale and scale factor
    By flyingal in forum AutoCAD Beginners' Area
    Last Post: 11th Jul 2012, 06:30 pm
  2. Inches and meters
    By bulletrick in forum AutoCAD Drawing Management & Output
    Last Post: 16th Jan 2006, 02:52 pm
  3. Dimensions don't scale to Viewport scale
    By brooksn in forum AutoCAD Drawing Management & Output
    Last Post: 6th Jul 2005, 06:18 pm
  4. Drawing in Millimeters
    By corbins in forum AutoCAD Beginners' Area
    Last Post: 30th Mar 2005, 02:47 pm
  5. re scale
    By monkey in forum AutoCAD Drawing Management & Output
    Last Post: 20th Apr 2004, 11:55 pm
