halam Posted March 1, 2016 Share Posted March 1, 2016 I have modelled a railing with earlier but i know is new feature that could make thing maybe more easy to adjust because of the parameters. Somehow i cannot figure out how this works in 3D. It acts strange. Check the dwg. The railing supoose to follow the line but i cannot get to this possition. Anyone? Thanks 3D-leuningwerk_2.dwg Quote Link to comment Share on other sites More sharing options...
MillerMG Posted March 7, 2016 Share Posted March 7, 2016 To me it seems like you haven't set the basepoint in the correct location Quote Link to comment Share on other sites More sharing options...
MillerMG Posted March 7, 2016 Share Posted March 7, 2016 You need to rotate the railing that you want to follow the path with the other railing. Then you need to place the railing on the 3D Polyline. Run the ARRAYPATH. I had no problem with getting it to look right. Let me know if you need any more help Quote Link to comment Share on other sites More sharing options...
halam Posted March 7, 2016 Author Share Posted March 7, 2016 Thank you! Basepoint was indeed not correctly. I found out that it works best if you properly align the first element. (somewhat different than command that does it automaticly) I like arraypath now .. 3D-leuningwerk_2.dwg Quote Link to comment Share on other sites More sharing options...
MillerMG Posted March 8, 2016 Share Posted March 8, 2016 Excellent! Good Job!! Quote Link to comment Share on other sites More sharing options...
