Results 1 to 3 of 3
    Senior Member Cadastrophic's Avatar
    not specified
    Dec 2002
    Australia
    152
    Default Can I flatten a tube to make a cutting template?
    I know there are dedicated programs to "flatten" 3D tubes to make cutting patterns for steel tube constructions, but I wonder if this is possible in AutoCAD solids 3D?
    Anyone have experience of this?
    I'm sure you said "Hurry up and DELETE your work".
    AutoCAD 2004, Inventor 8.
    AMD Athlon 64 FX-55, 3GB RAM, NVIDIA Quadro4 980XGL, Windows XP Pro.
    Super Member
    AutoCAD 2007
    Aug 2003
    Livingston, Scotland
    995
    not in vanilla Acad. if you have any experience programming, you could probably create something workable but if you have a real need for the programme you would be better buying one
    ResourceCAD.... the Resource for your CAD Solutions
    Senior Member
    AutoCAD 2008
    Oct 2003
    Germany
    228
    Try out my unfolding program from www.black-cad.de
    It will unfold any (unfoldeable !) 3d-surface area, which is bounded by an upper and a lower 3d-polyline.
    Good luck
    Jochen
