aloy Posted March 3, 2016 Share Posted March 3, 2016 (edited) Hello everyone, I have created a 3d polyline with the following code: (defun Bigal2(lst) (setq x 0) (command "_3dpoly") (while (= (getvar "cmdactive") 1 ) (repeat (length lst) (command (nth x lst)) (setq x (+ x 1)) ) ) ) (setq pl '((5 5 5) (10 5 4) (10 10 3) (5 10 2) (5 7 1) (5 5 5))) I then try to pick the same with the following line: (setq sel1(ssget '((0 . "_3dpoly") (8 . "0")))) It doesn't seem to work. What can be the problem?. Thanks to BIGAL who gave the code for the creation of the "3dpoly". Edited March 3, 2016 by aloy Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted March 3, 2016 Share Posted March 3, 2016 The entity type (DXF Group 0) for a 3D Polyline entity is "POLYLINE", with bit code 8 enabled in DXF Group 70 to differentiate the entity from a 2D Polyline or Mesh. Therefore your selection filter will need to be: '((0 . "POLYLINE") (8 . "0") (-4 . "&=") (70 . ) Quote Link to comment Share on other sites More sharing options...
aloy Posted March 4, 2016 Author Share Posted March 4, 2016 Thanks very much LM. It works well. Perhaps this could be the solution to the thread under the heading "Poyline error" started by me couple of days ago. Quote Link to comment Share on other sites More sharing options...
