Results 1 to 2 of 2
    Forum Newbie
    AutoCAD 2015
    Mar 2016
    1
    Default Polyline global width keeps changing to varies?
    Hi all,
    I am using AutoCad 2015, the problem I have is that when I select a polyline, do select similar and change the global width to 0.15 (for example) then when I save the drawing and re-open it, when I select the polyline and select similar, it says the global width is varies. I know this sounds like a rather minor problem but at work, everything gets checked and these kind of small errors do have a rather large effect on our performance rating. The strange thing about this is that it only happens for some drawings and not all drawings. Unfortunately that is all the information I really have on the problem so I hope that is enough.
    Thank you for your time,
    Josh
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    Can you post a .dwg that does this?
  1. Polyline with Global Width
    By prodromosm in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Oct 2014, 08:01 am
  2. changing global width of a rectangle
    By lesliematt in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Jul 2010, 05:29 pm
  3. Polyline Global Width vs Lineweight
    By viriato79 in forum AutoCAD Beginners' Area
    Last Post: 16th Feb 2010, 04:07 pm
  4. Draw Polyline with global width?
    By comcu in forum AutoLISP, Visual LISP & DCL
    Last Post: 2nd Jul 2008, 10:32 am
  5. Replies: 0
    Last Post: 24th Jan 2007, 11:10 pm
Tags for this Thread
