Results 1 to 5 of 5
    Forum Newbie
    AutoCAD LT 2016
    Mar 2016
    1
    Embarrassed Array count within Dynamic block
    Hello all!
    Let me first say that I've been looking through some of the threads on this forum and am blown away by the knowledge and creativity some of you possess. It's ridiculous the things you guys are able to do with AutoCAD.
    With that said, I'm hoping someone can help me solve a difficult problem I've been having. I've never created dynamic blocks and am learning as I go. I've scoured the internet looking for the answer for my needs and have experimented for hours but am still left without a working block.
    --A quick note before I begin, I'm using AutoCAD LT 2016 for all of this--
    What I'm trying to do is create a dynamic solar panel block that can accomplish three things:
    1. Dynamically fill a distance (up to 310' for fire code) with solar panels
    2. Have three visibility states representing different angles for the solar panels
    3. Have a solar panel counter that is visible within the properties but doesn't actually show up in the model
    Bonus: Dynamically fill an area with solar panels with the same requirements
    So far I've been able to accomplish #1 and #2 but to a limited degree. I can fill a distance just fine but if I change visibility states, the length is reset back to it's original. I need to be able to change visibility states without the length going away.
    #3 is the real problem. I have tried dozens of Attribute Definition combinations but can't seem to find one that works.
    The bonus would be nice to accomplish and I was able to do so with some success but didn't try to implement the visibility states or counter given the difficulty I've found just trying to make the lengthening block.
    I'm sure there are those of you that could create my block in no time at all and while I do appreciate that, what I'm really wanting is to learn what mistakes I'm making and how to do fix them myself. I've attached both the block that I've made as well as a file (posted on this very forum) that essentially recreates what I'm trying to accomplish (with a few tweaks e.g. I'm limited to using architectural units and I don't want a visible counter).
    Any help or direction would be greatly appreciated!
    Fixed Solar Module 1.dwgchairtest.dwg
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,115
    As they say a picture is worth a thousand words, so attached is a block that hopefully does what you want. It would take forever to try and describe the slight adjustments. Your block is well done, just a few simple changes, but it is things that you pick up by practicing.
    The fact that swapping between visibility states results in your array going back to the starting point is that you have used 3 linear parameters, one for each visibility state, this isn't neccessary, a single linear parameter can be used so long as it is visible in all three states, you only need to select different objects that are visible, but all the objects are included in the same selection set. (I hope that makes sense).
    To get a count I used an attribute that contains a formula and set it's visibility property to invisible. I had to adjust the length of your linear parameter, Architectural units are fine but not very accurate at reporting distances (your linear parameter was actually 4'-11 4/64" and a bit!!).
    I hope this works as you want, if you need help understanding any of the points please ask, I know how frustrating it can be figuring out what is what in dynamic blocks.
    Forum Newbie
    Surveying
    AutoCAD LT 2017
    Mar 2017
    2
    Default Counting Formula
    Hi Steven-g,
    Your solution sounds like what I'm looking for; I wonder you wouldn't mind elaborating on the formula?
    I have a dynamic block with an array (on a linear parameter) and I want a way of counting the number of iterations of the block.
    I think your formula would at least count the number of iterations per block insert, although in an ideal world I'd like to be able to quickly calculate the total number of visible blocks (all the insertions of the block and their iterations).
    Forum Newbie
    Surveying
    AutoCAD LT 2017
    Mar 2017
    2
    My last post was referring to this comment... not sure if you'll get notified of this post if I don't reply directly!
  5. #5
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,115
    The formula in the original post, is used to find how many objects are in the array, the linear parameter "distance1" was 1' 7-23/64" longer than the array offset? and the resulting length is just divided by the array offset. You just just have to find the correct numbers by measuring or using the properties toolpalette. To find the values for all blocks in the drawing you will need to use ATTEXT, or if you use full Autocad I think Dataextraction will do it.
  1. Dynamic block Chained array - force first array object to not show
    By yonderbob in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 26th Feb 2016, 02:01 pm
  2. Array Number/Count Dynamic Block
    By Ranime in forum AutoCAD Drawing Management & Output
    Last Post: 14th Oct 2015, 02:18 pm
  3. dynamic block - array
    By iicad in forum AutoCAD Drawing Management & Output
    Last Post: 20th Feb 2015, 06:48 pm
  4. Adding Array Count to Dynamic Blocks?
    By TuFoFi in forum AutoCAD Drawing Management & Output
    Last Post: 25th Oct 2012, 03:35 pm
  5. Question about the dynamic block count in a data extraction table
    By Jpier in forum AutoCAD Beginners' Area
    Last Post: 16th Dec 2010, 02:03 pm
Tags for this Thread
