Results 1 to 7 of 7
    Forum Newbie
    AutoCAD 2013
    Mar 2016
    1
    Unhappy plotting to pdf not accurate
    hello I'm quite new to autocad but I'm slowly learning, anyway I know enough to make a floorplan and etc. The problem is when I plot it to pdf, I know you have to set up the viewport and page set up manager and all the basic stuff. I've done all of that already but when I plot it to pdf at actual size it's always off by like .5 cm ( I use a 1:100 scale) I measure on screen with a triangular scale.
    I've always had this problem and I thought that it was either my pdf viewer (at 1st I was using mozilla's) so I switched to nitro reader, but nothing was happening it was still not accurate. (also if you ask why I don't use acrobat reader, it's because whenever I try to install it on my desktop all my icons become pdf files and won't open anymore) please help me, It's so frustrating not having accurate dimensions. by the way I use autocad 2013 version.
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    measure on screen
    Press the magic buttons for you screen size and it will then work ! You can not measure of the screen.
    If you have plotted onto paper and the scale is wrong I would bet its because you have done a "fit" as the plot method. You need to use actual size, a check of our pdfs and we would be lucky to be 1-2mm wrong on a A1 plot.
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    The last time I put a scale to a screen, it was a CRT. I wasn't taking actual measurements. That was my way of doing reference scaling.
    Drafting is a breeze.
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,595
    Thousands, if not hundreds of thousands of AutoCAD users have been printing to PDF just fine for years.
    If there was a scaling issue, it would be common knowledge.
    You are making a mistake at some point in the process, either while printing from AutoCAD to PDF, or in the process of printing the PDF to Paper.
    R.K. McSwain
    CAD Panacea | twitter
  5. #5
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Attach a copy of the drawing to your next post so we can take a look at it ourselves. Perhaps someone will even attempt to plot it to PDF.
  6. #6
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    Quote Originally Posted by ddddsss View Post
    It looks like BIGAL was the only other one to catch this, even though it was mentioned in both responses. This is not a way to verify accuracy of a PDF.
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    I saw it and just laughed.
  1. Accurate involute.
    By Lurking in forum AutoCAD Beginners' Area
    Last Post: 1st Dec 2012, 12:02 am
  2. accurate sketch up dimensions?
    By The_Cad_Kid in forum SketchUp
    Last Post: 26th Dec 2009, 04:51 am
  3. How accurate
    By grain in forum SketchUp
    Last Post: 7th May 2009, 01:07 pm
  4. is more accurate angle precision possible?
    By NoelStalker in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 6th Apr 2009, 05:29 pm
  5. How to extend arc in accurate length from end point
    By rengised in forum AutoCAD Beginners' Area
    Last Post: 13th Oct 2008, 08:12 am
Tags for this Thread
