Results 1 to 10 of 10
    Forum Newbie
    bend's Computer Details
    Windows 10
    Surveying
    bend's Discipline Details
    Surveyor
    Surveying
    AutoCAD 2017
    Feb 2016
    Aus
    8
    Default Hatch Poly Lines in a particular layer
    Hi,
    I am trying to get some advice on the best way to hatch multiply poly lines in any particular layer.
    I do not want to manually hatch each poly lines as there are dozens in multi files and was hoping to get some help with a simple script.
    I have attached an example of what I will be working with the layer I wish to hatch is 1129.
    Any help would be greatly appreciated.
    Cheers bend
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    One way would be to isolate the layer (1129) then hatch all the closed polylines. A second option would be to use a custom lisp routine but you would have to supply some further information such as the name, scale and angle of the hatch pattern you wanted to use.
    Question. Are you also hatching areas where the closed polylines overlap each other?
    Forum Newbie
    Windows 10
    Surveying
    Surveyor
    Surveying
    AutoCAD 2017
    Feb 2016
    Aus
    8
    Yes in some cases the hatch will overlap.
    The hatch is "cross" scale is "0" and angle is "0". The lisp routine was what I was thinking due to the large number of files.
    bend
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    Scale of "0"? No way.
  5. #5
    Forum Newbie
    Windows 10
    Surveying
    Surveyor
    Surveying
    AutoCAD 2017
    Feb 2016
    Aus
    8
    Scale "10"
    missed a 1
    bend
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    That sounds a lot better.
  7. #7
    Forum Newbie
    Windows 10
    Surveying
    Surveyor
    Surveying
    AutoCAD 2017
    Feb 2016
    Aus
    8
    Hey mate,
    just seeing if you had any more thoughts with this.
    bend
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    Not recently as I have been busy helping another member with a 3D model problem. I would have thought by now that one of the lisp gurus would step in with a nifty routine that would solve your problem. I found one myself, elsewhere, but for some strange reason it refused to work on your geometry but would work on geometry I created.
    I think I figured out why the routine I tried did not work on your drawing. It appears the drawing does not use normal polylines but instead uses 3Dpolylines (at different elevations with differing vertex 'Z' values). BIG difference! I think that is something you should have told us right from the beginning don't you? I don't think you will be able to hatch these objects in the way that you want.
  9. #9
    Forum Newbie
    Windows 10
    Surveying
    Surveyor
    Surveying
    AutoCAD 2017
    Feb 2016
    Aus
    8
    Thanks for looking at it. The data is a bulk export I have done through another software package and if I had known it would cause such a BIG issue I would have allowed for it. This being considered is there any chance I could have a look at the routine you found.
    Within the original files I can write something that will average the RL and flatten all the corresponding poly lines.
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    Search on the following criteria and you'll find everything I did.
    "autocad"+"hatch"+"layer"+"lisp"
  1. Subdividing height lines between two (poly)lines
    By TheDude in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 5th Sep 2015, 02:29 am
  2. Poly lines
    By skenderbender17 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 11th Oct 2012, 03:51 pm
  3. Poly lines
    Last Post: 21st Sep 2011, 09:32 pm
  4. Use color faces, hatch or poly face mesh?
    By fitterhans in forum AutoCAD 3D Modelling & Rendering
    Last Post: 19th Jun 2008, 01:45 pm
  5. 3d (poly)lines with width
    By nasko in forum AutoCAD Drawing Management & Output
    Last Post: 16th May 2005, 06:20 pm
Tags for this Thread
