DeadlyToad Posted March 15, 2016 Share Posted March 15, 2016 I need to make two flats on OD of my part. Not sure how to do that. -Thanks Quote Link to comment Share on other sites More sharing options...
Cad64 Posted March 16, 2016 Share Posted March 16, 2016 I have moved your question to the Solidworks section: http://www.cadtutor.net/forum/forumdisplay.php?44-SolidWorks Quote Link to comment Share on other sites More sharing options...
shift1313 Posted March 16, 2016 Share Posted March 16, 2016 We are going to need a bit more information. If its just a cylinder(extruded circle) there are many ways to do this. You can use an open sketch to "split" the body. Same sketch can be an extruded surface and cut the solid. You can create a closed profile and extrude-cut it etc. Need to know if the od of your part is just a cylinder or something else. Is the flat defined by its distance from the center, shape/area on the surface, location based on x/y/z and so on. Also what is your experience level? Quote Link to comment Share on other sites More sharing options...
