Results 1 to 7 of 7
    Forum Newbie
    AutoCAD 2015
    Mar 2016
    5
    Drawing How to create rebar dimension lisp in autocad
    Help me to create a lisp that can do for me these task that i do every day and I wanted a short way to do it as shown in the attached image
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,454
    Hi,
    I think your thread should be moved in the autolisp's discussion by the moderator.
    You must explain more clearly what are you trying to achieve, do you want to dimension a polyline by picking it?
    Try with simplier explanations, using autocad terms. Its hard to understand what exactly is your everyday's task.
    Forum Newbie
    AutoCAD 2015
    Mar 2016
    5
    Default Rebar dimesion
    i want to create a rebar dimension that can be stretched and when stretched it writes the number of items between; calculated with the division of the by the spacing stated and also to write ''number, bar notation, bar diameter-bar position-spacing description '11T12-02-200 B1'", On the dimension line.
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,454
    Well to answer partially, I think theres a lisp that dimensions at incremented distance of a polyline (if your rebar is a polyline).
    The "number, bar notation and bar diameter and position" might be easier to achieve by creating a dynamic block,
    since with lisp it would expect to read that information from somewhere or you should manually input it while running the routine.
    Providing a sample drawing with "before and after" would make the job easier for the coders.
    But my opinion is that it would be easier to achieve the task if you create a dynamic block with attributes and fields, and populate the data.
    From lisp you could expect stuff like auto-dimensioning and auto-numbering, but it could not populate the notation and diameter (unless it reads a circle's diameter for example).
    Try to imagine yourself as a code-writer, what information would you need to get first so you would know how the code will auto-populate the rebars.
  5. #5
    Forum Newbie
    AutoCAD 2015
    Mar 2016
    5
    Please I would like someone to show me how to do it even in Vba or visual studio. my major problem is get an automatic rebar detailing aid.
  6. #6
    Senior Member
    iconeo's Computer Details
    Windows
    Multi-disciplinary
    iconeo's Discipline Details
    CAD Manager/Draftsman
    Multi-disciplinary
    AutoCAD 2017
    Jun 2007
    Seattle
    306
    Going to second Grrr here. I feel that a dynamic block would be the better solution. If you provide a sample drawing I might take a crack at it.
    Thanks.
  7. #7
    Forum Newbie
    AutoCAD 2015
    Mar 2016
    5
    Default I have attached a dwg
    I have attached the dwg 2007 format Rebarline.dwg
  1. Create Dimension Style Using Visual Lisp?
    By ksperopoulos in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Feb 2016, 07:08 pm
  2. Penn Foster Drafting with AutoCad Structural help with the rebar.
    By Hondatek in forum Student Project Questions
    Last Post: 17th Sep 2015, 01:05 am
  3. Lisp routine for Rebar Layout
    By guyzen2004 in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th May 2014, 06:08 am
  4. Need help !Use lisp Create text style & dimension style.
    By lucas3 in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Jan 2014, 05:53 pm
  5. dimension style create (plz chk my new lisp & how to improve)
    By autolisp in forum AutoLISP, Visual LISP & DCL
    Last Post: 31st Jul 2010, 08:01 am
Tags for this Thread
