Results 1 to 5 of 5
    Full Member DesmetMartin's Avatar
    DesmetMartin's Computer Details
    Windows 7- Professional 64bit
    16GB
    NVIDIA Quadro K4200
    HP Z22i IPS Display
    AutoCAD 2016
    Mar 2016
    Belgium
    45
    Default Layer Lisp Question
    I have a Lisp from Lee Mac which I would like to be modified.
    I would like to have a setting that let's you choose which layer it should be on.
    I have tried to write something myself and only came up with this:
    Code:
    (setq TASH (getint "\nChoose dimensions layer: Dim. (1), Front view (2)"))
      ); end while
        ); progn
      );TASH = 1, Dim
      (if (= TASH 1 )
          ; S-Dimensions
            (command "DIM*"		       		"S-DIMENSIONS"   "Dimension Layer"              3        "Continuous"           -3                 1       	    nil         )
        ); progn
      ); if (= TAMR 1)
    and:
    Code:
    (defun CommandReactor:CommandWillStart (rea cmd)
      (if (wcmatch (strcase (car cmd)) "*DIM*")
          		(setq *OldClayer* (getvar 'clayer))
          			(vla-add
    			        (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
      						); end while
          (setvar 'clayer layerName)
    But I don't know were to put it in the existing lips from Lee Mac.
    Can anyone help?
    The lisp from Lee Mac is now;
    Code:
    http://lee-mac.com/lisp/html/LayerDirectorV1-4.html
    Thanks!!
    Ps. Check out Lee Mac's lisps!
    Super Member
    Civil 3D 2015
    Aug 2015
    508
    First off, as part of Lee's terms of use, he doesn't want others posting his codes, but rather a link to them, see this link: http://lee-mac.com/terms.html. Lee is awesome to provide these programs, so please just delete his code above. Now onto your question, the easiest way to do this is to have a new LISP routine that calls two different versions of Lee's program. Have two different copies of his program (you will need to rename the functions in the 2nd one). You then would call both programs in another LISP routine that turns on either program a, program b, or turns them off.
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,591
    Thank you broncos, I very much appreciate your respect & support.
    DesmetMartin, please refer to my response to your email enquiry sent through my site - I have provided a prototype version of my Layer Director application which incorporates a VIEWDIR test to enable automatic dimension layer selection depending on your view configuration.
    Lee
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    16GB
    NVIDIA Quadro K4200
    HP Z22i IPS Display
    AutoCAD 2016
    Mar 2016
    Belgium
    45
    @Broncos15; I changed it immediately, I did not know this was in Lee Mac's terms. My apology for this.
    @ Lee mac; First of all: thanks for the fast responds!
    Second: The responds I got from you is with Viewdir.
    But is it possible to get a "question" which layer you want when you want to place a DIM, and if you then press a number you get the layer which you choose?
    For example:
    --> I got this but I can't find how to get it linked to the layers.
    Thanks!
    - DesmetMartin
  5. #5
    16GB
    NVIDIA Quadro K4200
    HP Z22i IPS Display
    AutoCAD 2016
    Mar 2016
    Belgium
    45
    Can somebody still help me?
  1. Replies: 2
    Last Post: 8th Jan 2016, 11:11 am
  2. lisp to change layer properties if layer name contains text
    By pnoraa in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Sep 2013, 11:58 am
  3. Lisp that will select layer and draw VP and go back to previous layer
    By matthewrussell in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Jan 2009, 09:21 pm
  4. layer group and general layer question
    By jkristia in forum AutoCAD Beginners' Area
    Last Post: 29th Nov 2008, 12:56 pm
  5. Tough Question - Layer Locking (Make Layer Visible But No Pick)
    By johnshar123xx in forum AutoCAD General
    Last Post: 21st Nov 2008, 03:20 pm
Tags for this Thread
