Surface join
Butch
Hi folks!
I created an grading surface on top of an egsisint surface.
The grading surface has CUT and FILL geometry.
How can I join the Grading surface and Egsisting surface so that they behave as one surface and that I can see cutting geometry?
I know that anyone that can help you out will be asking for the drawing. If you could upload it, it might help with someone trying to answer you question
Under Surfaces, Definition you can do Edits so you should be able to make a new blank surface then paste Existing then Grading the result should be the two surfaces combined. Note order of pastes.
