Results 1 to 6 of 6
    Forum Newbie
    AutoCAD 2015
    Mar 2016
    2
    Exclamation Aligning multiple lines at once
    Hello folks!
    I would like to know if you guys could help me to align multiple lines to an specific point.
    Take a look at this image. I want to align all color lines to the white one at the bottom.
    I tried to move them, but I need a reference point and I do not know how to do it.
    Ive been searching about it here, but also unsuccessful.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Image missing?
    OK...since I see no evidence of an image I'll take a wild guess here and say try using the ALIGN command. Your Help file will give you the particulars on how it is used.
    AutoCAD 2013
    Nov 2011
    6,056
    Welcome to CADTutor Lucas.
    Check out this Lyn Allen link, regarding the use of the CHANGE command.
    http://lynn.blogs.com/lynn_allens_bl...e-command.html
    The part dealing with your question is near the end of the clip.
    Forum Newbie
    AutoCAD 2015
    Mar 2016
    2
    Thank you Dadgad for wlecoming me.
    I tried to use CHANGE but its not working as I neeed.
    I need to put all lines together on the same plane, same elevation in that case, but do it at once!
    I fixed the missing image file on my first post.
    Thank you and hope it can help you to help me!
  5. #5
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,147
    Perhaps the picture does not show a plan view??
    Perhaps Flatten command would help.
    It would be easier to help you if you could post the drawing file.
  6. #6
    AutoCAD 2013
    Nov 2011
    6,056
    Quote Originally Posted by lucascantelle View Post
    If you use the ELEVATION option in the CHANGE command you can do that too, just determine the elevation of that one line first, then specify that as the new elevation value, after selecting all of the lines (follow the commandline prompts).
    Another way to do this would be using Properties or QUICK PROPERTIES, by selecting all of the lines or plines, and setting the Z Start values and Z End values to whatever the desired Z value is.
  1. Aligning multiple 3D objects
    By Jordan27 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 13th Jun 2015, 07:53 am
  2. Aligning Multiple Text Objects?
    By ILoveMadoka in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 3rd Oct 2012, 01:49 am
  3. Move lines, aligning the edges.
    By teknomatika in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Sep 2011, 03:16 pm
  4. Aligning multiple layouts
    By quixin in forum AutoCAD Drawing Management & Output
    Last Post: 12th Dec 2008, 04:50 pm
  5. Aligning/centering multiple polygons on a single point?
    By Anonymous in forum AutoCAD General
    Last Post: 10th Aug 2003, 08:33 pm
Tags for this Thread
