Results 1 to 2 of 2
    Forum Newbie
    AutoCAD 2016
    Mar 2016
    9
    Question Can I lock the MText box size? Fit MText?
    Hi!
    I have a text box containing mText with fields. I have drawn up the multiline box I want to have the text in, problem is that when the fields change the text gets longer and therefor makes the box bigger leading to my text no longer staying within the size its supposed to. Is there a way to fit mtext? Force it to stay within the set border and if more rows than fit are added, shrink the text?
    Thank you!
    Senior Member troggarf's Avatar
    troggarf's Computer Details
    Windows 8.1
    AutoCAD 2016
    Oct 2010
    Littleton, Co
    191
    I am wondering if setting the Column settings to a fixed width would help.
    Even if you don't need multiple columns you can simply drag the length of the first column down to give it more room.
    Select the MTEXT and in the Properties palette, click the dialog icon to the right of Columns in order to show the "Column Settings" dialog box.
    Set it to "Static" and then set the column width as shown below.
    ~Greg
    ~Greg B
    Have fun!! www
  1. changing mtext size in xref
    By andyr74 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 17th Oct 2014, 11:42 am
  2. Changing the size of the Mtext for 0001?
    By rodrigo_sjc_sp in forum AutoLISP, Visual LISP & DCL
    Last Post: 31st Jan 2013, 05:00 pm
  3. Varying text size in MTEXT
    By Cad Monkey 2 in forum AutoCAD General
    Last Post: 21st Mar 2011, 02:18 pm
  4. The old mtext caps lock check box
    By Galingula in forum AutoCAD Drawing Management & Output
    Last Post: 20th Aug 2007, 04:15 pm
  5. Can Lisp use mtext to make multi string mtext editor?
    By muck in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Dec 2006, 03:22 am
Tags for this Thread
