hanif Posted March 24, 2016 Share Posted March 24, 2016 My question is about Solid objects. I have an output from Abaqus program and they are only coordinates which i get after calculation. these are the deformed rockmass coordinates. Now i have to make a solid out of them and bring the new deformed rockmass as a solid to Abaqus program back. in this autocad file which is attached I have made different layers including different output forms the frist and second layers includs a command which imports coordinates from text file as a 3d poly 3th and 4th are layers including just points and the last one which is called test layer is just front and the back side of rockmass even in this layer if you use sweep commands it will make a solid but it doesn't connect the point in a proper way. Thanks test different options.dwg Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 24, 2016 Share Posted March 24, 2016 For starters I just have to ask. Why did you assign the same color to ALL the layers in your drawing? How does one differentiate between the layers visually? I would have thought that if this rock mass was captured as a point cloud in its entirety it would be easier to convert to a solid or is there something about point clouds I am not aware of that would preclude this? Quote Link to comment Share on other sites More sharing options...
halam Posted March 24, 2016 Share Posted March 24, 2016 I looked at your file but can not really see the question. Can you be more clear what you want to do? Tip: you can draw things and discribe them in DWG as well. use views, paperspace and stuff to get thing over... Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 24, 2016 Share Posted March 24, 2016 The OP is trying to create a properly shaped rock mass as a 3D solid model. He may have to resort to using AutoDesk Recap or Meshlab to achieve the end result he seeks. I'd recommend searching on the phrase "convert point cloud to 3D model". Quote Link to comment Share on other sites More sharing options...
