AutoCAD 2014
falcondor
Good day to all,
By using AutoCAD 2014 platform Windows 7, has recently been a huge file DWG ceased to open, there was an error: "File hangs or crashes AutoCAD."
Is there some way to fix the error and open the file?
Is there a .bak file? (usually in the same windows directory as the master file)
If so, you could try opening this by replacing the file name xxxxx.bak to xxxxx.dwg and see if that works for you.
I found this exact same question posted on 8 other forums dating back to January, so based on that I am closing this thread to prevent the inevitable spam for file recovery software.
This topic is now closed to further replies.
