JOHN W Posted April 4, 2016 Share Posted April 4, 2016 Hello, I believe someone here helped me with a copy/pasteclip issue I was having sometime last year, but I've forgotten the solution. Today, my ACAD began disallowing data copied to the clipboard to be pasted into the drawing file. Does anyone know a solution? Quote Link to comment Share on other sites More sharing options...
halam Posted April 4, 2016 Share Posted April 4, 2016 Googled this, did you try it? https://forums.autodesk.com/t5/autocad-2013-2014-2015-2016-2017/can-t-copy-paste-in-drawing/td-p/3455138 Quote Link to comment Share on other sites More sharing options...
RobDraw Posted April 4, 2016 Share Posted April 4, 2016 Is this for all files? I've seen this fail when necessary object enablers are not present or files created with verticals were not properly exported. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted April 5, 2016 Share Posted April 5, 2016 I have been having a similar intermittent problem of late, trying to past some Data Extraction tables into a dwg., very frustrating, and I haven't figured out my issue yet. Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 5, 2016 Share Posted April 5, 2016 Try using CTRL+V to do the pasting and see what happens. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted April 5, 2016 Share Posted April 5, 2016 I have been having a similar intermittent problem of late, trying to past some Data Extraction tables into a dwg., very frustrating, and I haven't figured out my issue yet. Have you tired using tables instead of OLE? Quote Link to comment Share on other sites More sharing options...
