Results 1 to 2 of 2
    Forum Newbie
    AutoCAD 2014
    Apr 2016
    3
    Default Errror Message :invalid input while assigning CanonicalMediaName
    Hi i am getting invalid input error message while assigning CanonicalMediaName=ANSI_E_(44.00_x_34.00_Inches)
    please help on that
    Please see the below VB.Net Code
    Dim rasterObj As Autodesk.AutoCAD.Interop.Common.IAcadEntity
    Dim Layout As Autodesk.AutoCAD.Interop.Common.AcadLayout
    Dim l_SheetCount As Integer
    Dim NewFile, codespot As String
    Dim i As Integer
    Dim resume2 As Boolean = True
    Try
    codespot = "SAP 1"
    NewFile = "monochrome.ctb"
    l_SheetCount = CInt(clsVariable.DrawingSheet)
    codespot = "SAP 2"
    Layout = Acad.ActiveDocument.ModelSpace.Layout
    codespot = "SAP 3"
    rasterObj = Layout.Block.Item(l_SheetCount - 1)
    If Not (Layout.CanonicalMediaName = "ANSI_E_(44.00_x_34.00_Inches)") Then
    End If
    Layout.PlotRotation = Autodesk.AutoCAD.Interop.Common.AcPlotRotation.ac0 degrees
    codespot = "SAP 5"
    If Not (Layout.StyleSheet = NewFile) Then
    If Not (Layout.StyleSheet = NewFile) Then ''if the style sheet can't be set, use none
    Layout.StyleSheet = ""
    End If
    End If
    codespot = "SAP 6"
    Layout.PaperUnits = Autodesk.AutoCAD.Interop.Common.AcPlotPaperUnits.a cInches
    codespot = "SAP 7"
    Layout.StandardScale = Autodesk.AutoCAD.Interop.Common.AcPlotScale.acScal eToFit
    codespot = "SAP 8"
    i = 0
    'Layout = Acad.ActiveDocument.Layers.Add("Junk") 'commented prasad
    'Set the layer named "Junk" the active layer for the current document
    Acad.ActiveDocument.ActiveLayer = Acad.ActiveDocument.Layers.Item("Junk")
    Acad.ActiveDocument.ActiveLayout.PlotType = Autodesk.AutoCAD.Interop.Common.AcPlotType.acExten ts
    Acad.ActiveDocument.ModelSpace.Layout.ConfigName = "HybridConverter.pc3" --Getting Error in this line
    ''Acad.ActiveDocument.Regen acActiveViewport
    Acad.ActiveDocument.ModelSpace.Layout.RefreshPlotD eviceInfo()
    Acad.ActiveDocument.ActiveLayer = Acad.ActiveDocument.Layers.Item("0")
    Layout = Acad.ActiveDocument.Layers.Item("Junk")
    Layout.Delete()
    codespot = "SAP 9"
    Application.DoEvents()
    Acad.Update()
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    Please read the Code Posting Guidelines and place your Code in Code Tags.
  1. Error message of Invalid Characters in File Name (AutoCAD LT2007)
    By Bud McK in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 4th Oct 2013, 05:47 pm
  2. Invalid or incomplete DXF input Error message
    By gbuckley in forum AutoCAD General
    Last Post: 11th Jun 2013, 04:02 pm
  3. invalid file error message
    By aslan_thr in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 15th Feb 2013, 01:57 pm
  4. Invalid URI Error Message
    By CJJ in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 2nd Mar 2012, 03:07 pm
  5. invalid load message from design centre
    By michaeloureiro in forum AutoCAD Drawing Management & Output
    Last Post: 21st Jan 2009, 04:52 pm
