PrasadUddanti Posted April 6, 2016 Share Posted April 6, 2016 Hi i am getting invalid input error message while assigning CanonicalMediaName=ANSI_E_(44.00_x_34.00_Inches) please help on that Please see the below VB.Net Code Dim rasterObj As Autodesk.AutoCAD.Interop.Common.IAcadEntity Dim Layout As Autodesk.AutoCAD.Interop.Common.AcadLayout Dim l_SheetCount As Integer Dim NewFile, codespot As String Dim i As Integer Dim resume2 As Boolean = True Try codespot = "SAP 1" NewFile = "monochrome.ctb" l_SheetCount = CInt(clsVariable.DrawingSheet) codespot = "SAP 2" Layout = Acad.ActiveDocument.ModelSpace.Layout codespot = "SAP 3" rasterObj = Layout.Block.Item(l_SheetCount - 1) If Not (Layout.CanonicalMediaName = "ANSI_E_(44.00_x_34.00_Inches)") Then Layout.CanonicalMediaName = "ANSI_E_(44.00_x_34.00_Inches)" End If Layout.PlotRotation = Autodesk.AutoCAD.Interop.Common.AcPlotRotation.ac0degrees codespot = "SAP 5" If Not (Layout.StyleSheet = NewFile) Then Layout.StyleSheet = NewFile If Not (Layout.StyleSheet = NewFile) Then ''if the style sheet can't be set, use none Layout.StyleSheet = "" End If End If codespot = "SAP 6" Layout.PaperUnits = Autodesk.AutoCAD.Interop.Common.AcPlotPaperUnits.acInches codespot = "SAP 7" Layout.StandardScale = Autodesk.AutoCAD.Interop.Common.AcPlotScale.acScaleToFit codespot = "SAP 8" i = 0 'Layout = Acad.ActiveDocument.Layers.Add("Junk") 'commented prasad Acad.ActiveDocument.Layers.Add("Junk") 'Set the layer named "Junk" the active layer for the current document Acad.ActiveDocument.ActiveLayer = Acad.ActiveDocument.Layers.Item("Junk") Acad.ActiveDocument.ActiveLayout.PlotType = Autodesk.AutoCAD.Interop.Common.AcPlotType.acExtents Acad.ActiveDocument.ModelSpace.Layout.ConfigName = "HybridConverter.pc3" --Getting Error in this line ''Acad.ActiveDocument.Regen acActiveViewport Acad.ActiveDocument.ModelSpace.Layout.RefreshPlotDeviceInfo() Acad.ActiveDocument.ActiveLayer = Acad.ActiveDocument.Layers.Item("0") Layout = Acad.ActiveDocument.Layers.Item("Junk") Layout.Delete() codespot = "SAP 9" Application.DoEvents() Acad.Update() Application.DoEvents() Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 6, 2016 Share Posted April 6, 2016 Please read the Code Posting Guidelines and place your Code in Code Tags. Quote Link to comment Share on other sites More sharing options...
