Results 1 to 5 of 5
    Junior Member
    Mechanical
    kite15's Discipline Details
    Service
    Mechanical
    This is a software company working in BIM industry.
    AutoCAD 2015
    Oct 2015
    india
    17
    Default Line type change in the selected blocks
    I have a code please, suggest to change the line type into selected blocks
    (vl-load-com)
    (or acdoc
    (setq acdoc (vla-get-activedocument (vlax-get-acad-object))))
    (if (setq ss (ssget "_:L" '((0 . "INSERT"))))
    (setq sn (ssname ss (setq i (1- i))))
    (if (not (member (setq name (cdr (assoc 2 (entget sn)))) l))
    (setq l (cons name l)) (vlax-for x (setq bd (vla-item (vla-get-blocks acdoc) name))
    (if (and (eq :vlax-false (vla-get-isxref bd))
    (eq (vla-get-linetype x) "Hidden 1_5"))
    (vl-catch-all-apply 'vla-put-linetype (list x) "0"))
    (if ss (vla-regen acdoc acAllViewports))
    (setvar "cmdecho" 1)
    Thanks
    Senior Member kpblc's Avatar
    AutoCAD 2005
    May 2006
    Russia, St-Petersburg
    361
    What did you mean by
    Code:
    Try to change it to
    Code:
    (vl-catch-all-apply (function (lambda () (vla-put-linetype x "<LineTypeName"))))
    And don't forget to change "<LineTypeName>" to requested value.
    P.S. Linetype should be already loaded to dwg
    All I say is only my opinion.
    Junior Member
    Mechanical
    Service
    Mechanical
    AutoCAD 2015
    Oct 2015
    india
    17
    Hi kpblc,
    Thank you very much its works..
    Senior Member nod684's Avatar
    nod684's Computer Details
    Windows 7 Home
    Architectural
    AutoCAD 2014
    Jul 2012
    Philippines
    345
    what i did is i downloaded the FixBlock.lsp here
    http://www.draftsperson.net/index.ph...ck_-_Free_LISP
    and change the Linetype to Hidden
    "Memories fade but the scars still linger...."
  5. #5
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,127
    Please read the Code Posting Guidelines and place your Code in Code Tags.
  1. Line Type Will Not Change
    By gsksun4 in forum AutoCAD LT
    Last Post: 3rd Oct 2014, 01:48 pm
  2. LISP Routine to change colour of all selected objects (except blocks)...?
    By lamensterms in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Jun 2014, 01:11 pm
  3. Break the line and change the line type
    By nalsur8 in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Jul 2011, 02:12 pm
  4. Line type scales change.... BIG PROBLEM
    By RICO in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 25th May 2011, 07:28 am
  5. Can't change line type, need some help guys.
    By T.A. Metal in forum AutoCAD Beginners' Area
    Last Post: 3rd Nov 2008, 05:08 pm
