Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
    Senior Member
    AutoCAD 2011
    Jan 2014
    169
    Default workspace: MAP classic
    Hi,
    Is there a way to set PERMANENTLY the workspace as MAP CLASSIC? So that each time i start it up i don't have to change it?
    SDI: is there a way to make this work? I have it set to zero, so that I would open each DWG in the same CAD window... but it's not working! I have SDI= 0 and each time i open a DWG I open up a new CAD!
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,108
    What CAD Program are you using? This doesn't seem to be an AutoCAD 3d Modelling & Rendering question.
    I moved your thread to the Map 3D Forum until more information is given.
    Senior Member
    AutoCAD 2011
    Jan 2014
    169
    thanks, well i hope someone will be able to answer, it looks like a super difficult question, and i haven't found anything online
    Super Member Murph_map's Avatar
    Murph_map's Computer Details
    Win 7, Win 8
    HP something or other and the laptop is an HP too
    2 gigs or 6 gigs in Laptop
    Utilities
    Murph_map's Discipline Details
    Boats and campers renting and repairs
    Utilities
    GIS and Map making.
    Map 3D 2016
    Feb 2011
    TN or KY depends if I'm at work or home.
    924
    workspace.pngAre you saving the workspace after you set it current? My image is from 2016 but should be the same as in 2011. Also are are SP installed?
    Murph
    Need a boat or camper for the weekend?
  5. #5
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,600
    Just a further suggestion save a work space as your own like "cat3appr" set current and save, I have the Auto save turned off so it can not be accidentally changed. If I make a change then I force a save. By having your own workspace you can always go back the out of box settings if something really stuffs up and start again.
  6. #6
    Senior Member
    AutoCAD 2011
    Jan 2014
    169
    thanks guys, I wish it was that easy... i've already tried that, see screenshot. My settings are always like this.
    I've done this in several different PCs and different CAD version, but nothing... when I restart CAD I need to re change to MAP classic workspace ..
    anything else? a lisp maybe?
    thanks!
  7. #7
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,600
    If you have played with a user profile then start autocad with default profile it is ignoring your workspace, CONFIG PROFILE check it. Also check your desktop icon properties have a look at the end for /p <<c3d metric>> this is default for Civ3d metric.
    Also try as I said make a new workspace, we have 9 pc's near me never had any problems.
  8. #8
    Senior Member
    AutoCAD 2011
    Jan 2014
    169
    thank you BIGAL, sorry it didn't work and the explanation has to be e more specific.
    I did modify the target in the properties icon of CAD and i added a template which was on classic map workspace and no ribbon. it just didn't work. first of all, i got the error attached , and second, the ribbon is still there.
    Is it really so complicated to set something that should be so straightforward? So far it's just easier to change to classic workspace and close the ribbon each time i open up cad. Strange there's nothing else.
  9. #9
    Super Member
    tombu's Computer Details
    Windows 7 64-bit
    Dell
    Civil
    tombu's Discipline Details
    Design Analyst
    Civil
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    814
    /w is the Command Line Switch for Workspace see reference at: http://help.autodesk.com/view/ACD/20...C-0D4E1EDF093A
    Put it at the end followed by MAP CLASSIC or whatever the name of the profile you want. Best to click Rename… on the Profiles tab in Options and copy it from there to make sure you get it exactly right.
    I don't think changing the profile is what you're looking for.
  10. #10
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Just how did you go about adding the classic workspace to Map 3D? Did you follow the procedure that can be found online at the AutoDesk website or did you just wing it?
    https://knowledge.autodesk.com/suppo...to-Map-3D.html
    How to force a workspace current upon start up (for AutoCAD and a wide range of verticals).
    https://knowledge.autodesk.com/suppo...n-startup.html
  1. Recreating the AutoCAD Classic Workspace in AutoCAD 2015 & 2016
    By The CAD Geek Blog in forum AutoCAD RSS Feeds
    Last Post: 10th Nov 2015, 02:00 pm
  2. Classic or Ribbon workspace
    By tonyj in forum AutoCAD General
    Last Post: 14th May 2013, 08:59 pm
  3. Civil 3D 2010 workspace to 2008 Classic
    By dstephens in forum AutoCAD General
    Last Post: 16th Jan 2011, 08:05 am
  4. 3d Classic workspace
    By Organic in forum AutoCAD 3D Modelling & Rendering
    Last Post: 18th Mar 2009, 10:05 pm
  5. ctb works in 2D/classic but not in 3D workspace
    By taqr07 in forum AutoCAD Drawing Management & Output
    Last Post: 24th Apr 2007, 05:59 pm
