MAREBER Posted April 16, 2016 Share Posted April 16, 2016 I am trying to plot and am being stopped completely by the attached image of a warning dialog box that comes up before I configure the plot properties AND once again after I click to plot. It will NOT go away the second time whether I click yes, no or try to X it out. So, I have to terminate CAD with the task manager. PLEASE HELP! Quote Link to comment Share on other sites More sharing options...
MAREBER Posted April 16, 2016 Author Share Posted April 16, 2016 I finally figured it out. Thanks. Quote Link to comment Share on other sites More sharing options...
Dana W Posted April 16, 2016 Share Posted April 16, 2016 This button. Either turn notification off, (see first image) or check the settings items the way you need, to get the layers reconciled. It is not enough to merely view the list of unreconciled new layers. While you are in the layer manager they must be reconciled(see second image). While reconciling layers in the layer manager, you can hold down the shift key and click on the first and last layer, to reconcile them all at once. Reconciling the new layers allows their properties to be brought into your drawing. Whether or not the properties of the new layers will work with your plot set-up, can then be dealt with. Quote Link to comment Share on other sites More sharing options...
MAREBER Posted April 16, 2016 Author Share Posted April 16, 2016 Thank you Dana! Quote Link to comment Share on other sites More sharing options...
