Jakub Posted April 19, 2016 Share Posted April 19, 2016 Hi, Does exist a lisp that read a text label of point and paste it as attribute? For example: I have a point in CAD that has a text label describing Z coordinate. I need a lisp that read this height and paste into "Z" row in geometry. Then it transforms point from 2D to 3D. Where can I find this type of lisp? Thank you for helping me in advance. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted April 19, 2016 Share Posted April 19, 2016 Hi, Upload a sample drawing. Quote Link to comment Share on other sites More sharing options...
Jakub Posted April 20, 2016 Author Share Posted April 20, 2016 Points are inserted as block. Quote Link to comment Share on other sites More sharing options...
satishrajdev Posted April 20, 2016 Share Posted April 20, 2016 (edited) try this :- For Text :- (defun c:test (/ a b c d i) (if (setq a (ssget '((0 . "text")))) (repeat (setq i (sslength a)) (setq b (entget (ssname a (setq i (1- i))))) (setq c (cdr (assoc 10 b))) (setq d (subst (atof (cdr (assoc 1 b))) (caddr c) c)) (entmod (subst (cons 10 d) (assoc 10 b) b)) ) ) (princ) ) For Block.... Change the Attribute Tag "A" as per your block tag :- (defun c:test (/ a b c d i) (if (setq a (ssget '((0 . "insert")))) (repeat (setq i (sslength a)) (setq b (vlax-ename->vla-object (ssname a (setq i (1- i))))) (setq c (vlax-get b 'InsertionPoint)) (setq d (vl-some '(lambda (x) (if (eq (vla-get-tagstring x) "A") ; Change tag here (atof (vla-get-textstring x)) ) ) (vlax-invoke b 'GetAttributes) ) ) (vla-put-insertionpoint b (vlax-3d-point (subst d (caddr c) c)) ) ) ) (princ) ) Edited April 21, 2016 by satishrajdev Quote Link to comment Share on other sites More sharing options...
CAD89 Posted April 21, 2016 Share Posted April 21, 2016 @Jakub - As far as I see in the properties palette, it says that you have nothing selected ... so with that in mind AutoCAD shows you the elevation of the cursor which in 2D view the default elevation of the cursor (or crosshairs whichever you prefer) will always be 0. In order for us to be able to offer you any help you must upload a sample file so we can see exactly what you are dealing with. @satishrajdev - I think that Jakub wants to elevate the block that represents the point and not only the text that is attached to it! Nice code btw. Best regards, CAD_89 Quote Link to comment Share on other sites More sharing options...
satishrajdev Posted April 21, 2016 Share Posted April 21, 2016 I have updated the code Quote Link to comment Share on other sites More sharing options...
