Karaibrahim Posted April 19, 2016 Share Posted April 19, 2016 Hi all and please excuse my posting if there is already an identical solved post. So, the thing is.. I would love to be able to click on an object that I have extruded and see the dimensions in all three directions. Currently, when i select an extruded object (prt sc attached) its quick properties height and z direction are 40 mm (as I would have expected), yet the x and y directions both read 0s. what could be the reason? Quote Link to comment Share on other sites More sharing options...
Dadgad Posted April 19, 2016 Share Posted April 19, 2016 Vanilla Autocad doesn't do that, probably some of the verticals might, like the Structural Detailing ones, or the BIM based ones. I use ProSteel which does that, because the shapes you are extruding come from an extensive database onboard, which describes those other dimensions. Quote Link to comment Share on other sites More sharing options...
