Results 1 to 4 of 4
    Senior Member
    Architecture 2013
    Dec 2009
    123
    Default Stairs and global cut plane
    Hello all,
    I have a simple case of stairs on first floor.Stairs Elevation = 0.
    Cut planed are configured to: 170 cm above first floor (for level 0.00) and 170 cm above second floor. In other words first cut plane is set to 170 and second to 470.
    When I display first floor and set the global cut plane to first cut plane (=170) Autocad displays the entire stairs as there is not cut (instead of showing a cut).
    When I set the global cut plane to second level the stairs are displayed as there is a cut (instead of showing no cut).
    The only solution I could find so far is using "Override display configuration cut plane" but this is not a good solution as I am using same stairs for both floors.
    Thanks for your help
    Senior Member
    Architecture 2013
    Dec 2009
    123
    Can any one help here? Thanks.
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2018
    Mar 2006
    Dallas, TX - USA
    9,068
    Not a lot of AutoCAD Architecture support on this forum, sorry.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    Senior Member
    Architecture 2013
    Dec 2009
    123
    I think that I have just found a bug in Autocad (2013).
    When the Height of the stairs equals to the absolute value of the elevation and the elevation of the stairs is negative (e.g. the height of the stairs is 295 and the elevation is -295) then the cut plane is not displayed (e.g. if the global cut plane is -120).
    If I change the elevation to -296 then the cut plane is displayed. THIS IS A BUG.
  1. Rotate UCS so that the Y = 0 plane becomes the ground plane?
    By crystalfarquhar in forum AutoCAD 3D Modelling & Rendering
    Last Post: 29th Sep 2014, 04:30 pm
  2. Plane at an angle to plane through axis
    By KarolR in forum Autodesk Inventor
    Last Post: 14th Jul 2013, 11:47 am
  3. [Help] I'm finding lisp copy from XZ plane to XY Plane
    By ketxu in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Oct 2011, 10:48 am
  4. Stairs Architect Desktop - Landing Half Way Through Stairs
    By mattbarb in forum AutoCAD Beginners' Area
    Last Post: 20th Apr 2008, 01:52 pm
  5. Drawing stairs from the xy-plane
    By Siberian in forum AutoCAD General
    Last Post: 2nd Jan 2007, 02:43 am
