field text in a linetype
battman
Hi All, i'm trying to make a new linetype with text, but i want the text to have a field that displays the length of the line. Does anyone know how to do this? Or if it's possible?
Any help would be much appreciated!
thanks ReMark, the reason I would want it to be a linetype though would be so that I can have multiple segments, like as a polyline, and it can display the total length of the polyline. I'm thinking something like the GAS linetype or the HOT WATER supply linetype, but where the text is a field.
On a single line it can be done using a dimension, but thats not applicable for a pline.
Like Remark what about just pick and update objects or search by layer etc.
Someone might know a way with LISP, you could use the measure command and insert a block with a field along a line/pline, you could of course add other text or a wipeout or background hatch
field.dwg
This is based on Steven-g dwg it will label but if you change the pline the blocks do not change, one way around this is to erase all the blocks move the pline then redo the (c:plen), this involves other routines but the method is quite simple using ssget "F" done below
Simplest is the need to be able to put the field in a .LIN
A,5.08,-5.08,5.08,-5.08,["G",STANDARD,S=1.8,R=0.0,X=-1.8,Y=-.9],-3 need the "G" to be a field.
(defun c:plen ( / obj)
(setq obj (entsel "Pick line or pline"))
; probably want a layer set here
(command "measure" obj "B" "len" "Y" (getdist "enter spacing"))
; pline co-ords example
; By Alan H
(defun getcoords (ent)
 (vlax-safearray->list
   (vlax-variant-value
     (vlax-get-property
   (vlax-ename->vla-object ent)
   "Coordinates"
(defun co-ords2xy ()
; convert now to a list of xy as co-ords are x y x y x y if 3d x y z x y z
(setq len (length co-ords))
(setq numb (/ len 2)) ; even and odd check required
(setq I 0)
(repeat numb
(setq xy (list (nth i co-ords)(nth (+ I 1) co-ords) ))
; odd (setq xy (list (nth i co-ords)(nth (+ I 1) co-ords)(nth (+ I 2) co-ords) ))
(setq co-ordsxy (cons xy co-ordsxy))
(setq I (+ I 2))
; erase blocks
(defun c:eraseblk ( / ss)
(setq co-ords (getcoords (car (entsel "\nplease pick pline"))))
(co-ords2xy) ; list of 2d points making pline
(setq ss (ssget "f" co-ordsxy (list (cons 0 "Insert"))))
(command "erase" ss "")
Edited by BIGAL
Thanks everyone,
BIGAL, I used the first code you wrote above and saved it as a .lsp, loaded it with appload, and used the command "plen" on steven-g's drawing. It placed a measurement along my pline in regular intervals, which is great! but the measurement was always 15.81 m... which was the length of steven-g's line that he drew. When I draw a new line, it doesn't know to measure that one. Maybe the answer is in the second code you provided... but my novice autocad brain doesn't understand what to do with it.
I tested the small plen again at 2000 as spacing on a new pline and works fine, you may need to play with the dynamic block in terms of scale etc for small distance.
Used Bedit to edit block maintain insertion point.
