Deby Ferdian Posted April 25, 2016 Share Posted April 25, 2016 (edited) How to lofting 2 regions object which one this shape have created by me before and want to lofting become one object shape? Or if there is another way such as; Extrude>> taper>> User defined>> define a height. Which would be used of this case only. I also attached the file for example, see below here: Want to Lofting 2 Regions!.dwg Edited April 25, 2016 by Deby Ferdian #problem of attached file! Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 25, 2016 Share Posted April 25, 2016 What file? Quote Link to comment Share on other sites More sharing options...
Deby Ferdian Posted April 25, 2016 Author Share Posted April 25, 2016 Sorry earlier time I got bit a problem but it wasn't anymore, you may whould to refresh the page,, thx for fast reply @ReMark Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 25, 2016 Share Posted April 25, 2016 Is this what you are attempting to do? Quote Link to comment Share on other sites More sharing options...
Deby Ferdian Posted April 25, 2016 Author Share Posted April 25, 2016 Yeah .. How did you do that? Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 25, 2016 Share Posted April 25, 2016 Well AutoCAD didn't seem to like that upper shape so I exploded the regions only to discover it was a spline so I converted it to a polyline via the SPLINEDIT command then did my loft. If you create regions out of the two polylines you'll end up with a slightly different end result. Quote Link to comment Share on other sites More sharing options...
Deby Ferdian Posted April 25, 2016 Author Share Posted April 25, 2016 (edited) Wow.. It's work!.. @ReMark thank you so much you are so helpful and Is it same way if I want to "extrude" the spline object with the "taper" methode leading to zero I mean really-really taper, where this spline have created from my picture above that I drawn? Edited April 25, 2016 by Deby Ferdian #correction! Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 25, 2016 Share Posted April 25, 2016 I don't know. Best way to find out is experiment. That's how you learn. Quote Link to comment Share on other sites More sharing options...
